Starting Problems
Starting Problems
Ok my 99 1500 5.9l truck, Dose not like to start, I have to push down the gas pedal and hold it and crank the truck for a few seconds for her to fire. Then the hole Truck shakes. But when I let go of the gas it will die. I have to keep on the gas and get the truck moving for the truck to stay running, And other time it will start like normal. with no problems.
Could this be a grounding problem or something else.
my family calls this a money pit, But I will never give
up on this truck!!!
Thanks everyone have a great day.
up on this truck!!!
Trending Topics
Had this happen on my truck a couple of weeks ago. Here is the set-up:
Used remote start to start truck. Got in the truck after about 4 minutes, put foot on brake to shift into drive, and the truck died because I had failed to put the key in the ignition and turn it. (DOH!)
Truck behaved just as original poster indicated. Drove it about 10 minutes having to baby the gas even at stops.
Went into restaurant to eat. Came out and truck started normally, idled normally, ran normally.
Did I do damage to the IAC? Was the IAC just stuck in some weird calibration with the engine getting cut off?
