About to buy a SCT Tuner and have some questions
Old Jan 9, 2013 | 05:28 AM
  #111
Halojm's Avatar
Halojm
Originally Posted by truckdriver12
is that anything wrong with the 160 thermostat?
Posted from Dodgeforum.com App for Android
I use to run a 160* stat, thinking the ram would run better if it was cooler. It ran for years like that without any issues. The heater will not be to warm in the winter, depending on your geographic location. As far as using with an SCT Tuner, hemifever recommended a 180*.
Old Jan 9, 2013 | 09:00 AM
  #112
160 is too low. Will probably cause your PCM to whine about engine too cold, too long.
Old Jan 9, 2013 | 09:51 AM
  #113
SilverSS's Avatar
SilverSS
Originally Posted by dlyter09
If a tuned truck cant spin 33's then there is some issues there.. My untuned death flashed trucks burn 33's and 35's like its got geo metro tires on it
My 98 with the 93 tune would spin just mashing the gas on dry pavement when I had the 33 12.50's. 3.55 gears and open rear end which probably helped. Never tried with any other tune.
Old Jan 9, 2013 | 11:50 AM
  #114
aofarrell2's Avatar
aofarrell2
Too cold for the engine to run properly. just know this: The colder the engine is compared to rated operatin temperature, the more wear, fuel usage, and less power. It's hard on a engine. Now with the 180* tstat, it won't hurt the engine. Only reason Dodge put a 190* tstat on the Magnums was to help comply with emmisions. Otherwise the LA which is what the Magnum was based upon used the 180* tstat, because they didn't have as strict of emmissions controls.
Old Jan 9, 2013 | 11:52 AM
  #115
dlyter09's Avatar
dlyter09
Run a stock 195.. Unless you live somewhere it doesnt get cold then run a 180...
Old Jan 9, 2013 | 12:49 PM
  #116
ChillyPhil's Avatar
ChillyPhil
I put Hemifever Tuning on my right window on the top. It might look a little off but i think it's because the window slants downward. But mines actually 265/75r and i can spin them sometimes when i take off sitting still. (Not powerbraking) But when I take off from a stop and turn, then i can just spin them till it catches.
And I'll be putting my 180* tstat in when it gets warmer. It's winter and cold where I'm at and it gets a tad above the middle line at 200*.
Not to take it completely off topic, but will ford ranger wheels fit on our trucks? Their 5 lug but I'm still not sure. I'll be goin tonight to try them unless they for sure won't fit.
Old Jan 9, 2013 | 01:33 PM
  #117
aofarrell2's Avatar
aofarrell2
What in the world would you want to put a less-rated Ford ranger wheels on your big RAM?
Old Jan 9, 2013 | 01:38 PM
  #118
dlyter09's Avatar
dlyter09
They wont fit..
Old Jan 9, 2013 | 01:52 PM
  #119
aofarrell2's Avatar
aofarrell2
That's what I was thinkin.. And even if they did they are not rated for a RAM.
Old Jan 10, 2013 | 08:26 AM
  #120
ChillyPhil's Avatar
ChillyPhil
Yeah i was just checking cause he had some semi-new 31s all terrains on them and only wanted 100 for all 4 wheels and tires. But yeah, i guess they are 5x4.5 cause they didn't line up.
