transmission numbers and identification
Old 01-06-2016, 07:48 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
Yep. Sure would. The difference is the governor. ON the RH versions, it is mechanical, with flyweights, and the whole nine yards. On the RE, there is a solenoid, and sensor, and it's all controlled by the PCM.
  #32
Old 11-25-2017, 09:47 AM
rrrcoo's Avatar
rrrcoo
rrrcoo is offline
ok glad you all understand these codes so i am asking for help here. My transmission shows PK53007786 0785 9176 can you tell me what model and info that is? Its in a 91 W250 auto with a 360. Thanks in advance
  #33
Old 11-25-2017, 11:32 AM
HeyYou is offline
Looks like its an A518 (46RH) without locking converter......
  #34
Old 11-25-2017, 12:16 PM
rrrcoo's Avatar
rrrcoo
rrrcoo is offline
great. Thank you very much. Rookie question here but what does with locking/ without locking converter meann/change? It's a 4 speed including OD.
  #35
Old 11-25-2017, 12:51 PM
HeyYou is offline
On some of the older transmissions..... apparently they didn't do the locking converter thing. So, no Torque Converter Clutch. TCC locks the converter, so there is no slip, it makes for a direct mechanical connection from the engine to the trans. (good for better gas mileage.) Not sure why they didn't put a locking converter in there........
  #36
Old 04-30-2019, 12:01 AM
Keith Farr's Avatar
Keith Farr
Keith Farr is offline
Default 99 Dodge Ram 1500 4X4 5.9L V8 16 OHV
So do I have a 46RE then??
  #37
Old 04-30-2019, 09:09 AM
HeyYou is offline
Yep..
  #38
Old 11-08-2019, 02:51 AM
Mojo_motors's Avatar
Mojo_motors
Mojo_motors is offline
Default Trans identification
I’m dealing with a 2001 ram 1500 4x4 v8 automatic transmission. I’m almost positive I have a 46re but not sure since it is 4 wheel drive. Per your list here 4x4 models 1500-2500 year 96-99 have a 46re. Would I be correct thinking they would be the same?
  #39
Old 11-08-2019, 08:34 AM
HeyYou is offline
Yep, if it's an auto, its a 46RE.
  #40
Old 03-20-2020, 05:23 PM
wesley sandifer's Avatar
wesley sandifer
wesley sandifer is offline
I have this transmission with a part number pk521184312642 3564. Can you tell me what transmission this is? I'm trying to replace a 46rh with this one if it will work. And or what will it take to get it to work..?.
Quick Reply: transmission numbers and identification
