What next I have $$$$
Old Jan 4, 2013 | 02:25 PM
  #21
Lemunman's Avatar
Lemunman
I can't find 4.88 for the 9.25 31 spline
Old Jan 4, 2013 | 02:30 PM
  #22
gdstock's Avatar
gdstock
Where did you look? Check Randy's?
Old Jan 4, 2013 | 03:40 PM
  #23
Matt Nickerson's Avatar
Matt Nickerson
http://airram.com/product.php?catego...rchquery=yukon
^They will be Yukon brand 4.88 gears instead of Motive, see the note at the end.
edit: no carrier change needed for the rear. You can use thick cut gears for the front, or use "regular cut" with a 3.92 and up sized carrier.
Old Jan 4, 2013 | 06:28 PM
  #24
97tn4x4's Avatar
97tn4x4
I bought mine from completeoffroad.com. It all came as a package deal, I just called them and told them I wanted a thick cut for the front. My gears and LSD rebuild kit was around 650 ish.
Old Jan 4, 2013 | 06:30 PM
  #25
dlyter09's Avatar
dlyter09
seeing as in how the OP has 3.55 gears YES he will need a new carrier in the rear.. The front needs thick cut...
Old Jan 4, 2013 | 07:08 PM
  #26
Matt Nickerson
I read other threads where people swapped in 4.88 in the rear with no carrier change...but idk from experience
Old Jan 4, 2013 | 07:20 PM
  #27
dlyter09's Avatar
dlyter09
Carrier break is at 3.92.. Have to upgrade it for anything over that
Old Jan 4, 2013 | 07:24 PM
  #28
merc225hp's Avatar
merc225hp
Rear 9.25
Cover Bolts: 12
Ring gear diameter: 9.25 in
Carrier breaks: None
Axle shafts splines: 31
Available ratios: 2.71, 2.79, 2.94, 3.21, 3.55, 3.90, 4.10, 4.56, and 4.88
Old Jan 4, 2013 | 07:54 PM
  #29
dlyter09's Avatar
dlyter09
That's news to me.. the 4x4 shop that did my gears said there was a carrier break of 3.92... Good to know that's not true.
Old Jan 4, 2013 | 07:58 PM
  #30
Lemunman's Avatar
Lemunman
Thanks guys all this info is going to help me not get yanked around when I go to the shop . You guys rock
