Axle Gearing
to add more to this... youre telling me there front tires had so called "great" contact.... dont look to "great" to me.... just sayin
on top of that you didnt even have LT tires.... just plain jane passenger tires.... me thinks you need to be placed in a mental institution for a bit.
I see. Also I will answer to redneck, those are not passenger tires. They are cooper discovery 265/75/r15 st/c 8-ply e4 tires. Unless the tire place was wrong they told me they were good tires for towing and off-road.
It's abundantly clear that you have time to be on this forum asking reDONKulous questions.
You need to get off this site and go to IOWA Department of Transportation to bone up on your states vehicle code!!
Additionally, get the specs of said mystical 3500 or w/e flavor!!
According to our records, your vehicle was equipped from the factory
with the following:
Sales Code Description
*P1 Premium Cloth 40/20/40 Bench Seat
-D5
ADAP Light Group
AJKP Convenience Group
AJPP Power Convenience Group
APAS Monotone Paint
ASPP SLT Decor Group
BAUS 117 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS 11x2 Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CGTS Driver Air Bag Only
CHEP Deluxe Headliner
CKEP Front Seat Area Carpet
CLAP Front Floor Mats
CSPS Passenger Assist Handle
CSRP Passenger Assist Handles
CUDP Mini Overhead Console
DGB All 4-Speed Automatic Transmissions
DGTS 4-Spd. Automatic 46RE Transmission
DHAS Lock-Up Torque Converter
DHKS Shift-on-the-Fly,231HD Transfer Case
DJCS 195MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
EAAC All Engines
EML 5.9L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GFD Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNMP Passenger Side Sun Visor w/Mirror
GPUS Manual 6 x 9 Black Mirrors
GVAC All Vehicles W/O Power Mirrors
HAAP Air Conditioning
HGAP Hood Insulation
HGBS Dash Liner Insulation
JAYP Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBP Dual Note Electric Horns
JJJP 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
LAAP Ignition Time Delay Lamp
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LDAP Underhood Lamp
LMAS Halogen Headlamps
LPEP Cargo Lamp
MBFP Bright Rear Bumper
MCTP Bright Front Bumper
MDAP Front License Plate Bracket
MFDS Bright Grille
MHAS Black Windshield Moldings
MPBP Black Tailgate Applique
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCP Front Bumper Sight Shields
NAA Federal Emissions
NBKS EVAP Control System
NFVS 35 Gallon Fuel Tank
NHMP Speed Control
PW7A Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RASP AM/FM Cassette Radio
RCDP 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TYKP 245/50R20 BSW All Season Tires
TZAP Goodyear Brand Tires
WLBS Steel Spare Wheel
WNDP 16X7.0 Cast Aluminum Wheels
XBSS Pickup Box
XCMS Vendor Painted Cargo Box
YAAS Build To U.S. Mkt. Specifications
Some things have changed: As it now has a 265 tire instead of the 245 listed.
Also guys, one thing I want you to understand about me, like I stated we were hauling 15K, you all went through and we discussed it. At first I didn't quite understand what you were getting at, but I realized it later. So just be patient with me. I'll get your points, just might take a little time. That is the way I am. I hope you can all understand that and remember it. (Thanks, it helps me if you do.)
Ok, CDL laws in Iowa:
CDL Class A For a combination vehicle with a gross combined weight rating of 26,001 pounds or more where the gross vehicle weight rating of the towed unit is 10,001 or more pounds.
That's the one for trailer towing.
