Why'd you replace the cat? Because it was clogged? You know why it was clogged? Read the contents of that link again and then proceed to pull off your throttle body and check for pooled oil.
O2 sensors should also be replaced if they haven't been already...NTK or NGK brand
I only get like 210 miles to a tank and I do the math how much gas I put in and how far I went, I get like 8.5 or 9 no matter if I drive like a grandma or in NASCAR the truck has no loss of power by no means
No 5.2 or 5.9 has ever gotten 26 MPG. I've gotten 20MPG on a 5.9 but that is not the norm. Usually it gets around 16MPG. And it gets 8-10 towing last we checked. Chipped or not, I could only see a 3.9L get 26MPG.
what are you talking about? project rust bucket has a 5.9 and is has gotten 27mpg which is pretty good for a truck without overdrive or a lock up torque converter. project rust bucket can also put out 972rwhp. http://www.dieselpowermag.com/featur..._d250_cummins/
