WANT to turbo my 318
Old Jan 8, 2013 | 10:24 PM
sr20boostjunkie's Avatar
sr20boostjunkie
New Member
Arrow WANT to turbo my 318
Hi I'm new to the forum and American cars. I've mostly been around Nissan from a 240sx, 350 370z to r32 r35 gtrs. any way I have a 94 ram 5.2l 5sspd and I plan on doing a single turbo I just wanted to put my ideas and parts out there and see what you all think I will be doing a rebuild with new bearings rins gaskets ex ex I plan on getting 42 lb injectors fi elderbrock intake plenum/manifold I will fab all my own fmic pipes and manifolds too feed the turbo flip the stock ones I hope and add a y pipe now for ems ( engine management system ) I plain on useing megasquirt 2 I doubt we have a cas ( cam angel sensor ) so I think I will use a hall effect sensor and disk on the crank alltho I believe this will cause wasted spark and fuel since the crank spins 2 x one spin on the cam so it will spark on tdc and btcd I will run a dw 320 lph fuel pump tomie fpr fuel pressure regulator I don't want to do a fuel return system I only plan on 6_7 psi on a 60 trim t3 t4 Garrett turbo or Hx35 I will have a wideband o2 sensor gauge and a boost gauge I'm not sure who makes good parts for this truck like a clutch I know us Nissan guys get osgiken this truck is my winter snow truck so nothing crazy on the build for now if anyone can point me to a thread we're someone has done this that would help and thanks for any input. I'm tired so I'm sure I missed a few things and sorry for any spelling mistakes
Old Jan 8, 2013 | 10:38 PM
dlyter09's Avatar
dlyter09
There is a fella on here who has a turbo on his 5.2... Maybe he will chime in or you can send him a private message.. I beleive his username is Hahns 5.2
Old Jan 8, 2013 | 10:43 PM
Deadsquiggles's Avatar
Deadsquiggles
What kind of power are you looking for, more power at low rpms or higher up?
Old Jan 8, 2013 | 10:50 PM
oxymoron29's Avatar
oxymoron29
Since you're doing a rebuild why not just do a 390 stroker? Would probably yield same power output in a far more reliable manner not to mention eliminating any fab work.
Old Jan 8, 2013 | 11:08 PM
Deadsquiggles
I didn't even think about suggesting that.
Old Jan 9, 2013 | 12:02 AM
crazzywolfie's Avatar
crazzywolfie
https://dodgeforum.com/forum/2nd-gen...-5-2-dyno.html
Old Jan 9, 2013 | 03:46 AM
kejobe's Avatar
kejobe
And not to sound like an @ss, but punctuation helps too. I now have a headache.
But yes, it is possible. There are a couple threads here about boost. And IIRC, it is Hahns 5.2 .
Old Jan 9, 2013 | 07:43 AM
sr20boostjunkie
New Member
Power wise I just would like around 300_325 hp but I want around 425 tq I figure it will male what it wants. I'm use to a 2500lb car with 350 rwhp and 305tq so driveing this truck to me is slow its hard to merge onto 95 just getting to 55_65 mph is a struggle and I don't want to beat on it just to get there I do plain on running 35 inch tires so I know that will hurt my acceleration . This truck only sees snow and cold wether. I'm also just not a fan of supercharges and with the stroker kit I'd rather do a stroked 5.9l some day. I figure this little 318 and some boost should be enough for me now . I have seen a few threads that that guy Hamas5.2 (sp) chimed in I know that's not how to spell.that sorry lol well I'm off to work
Old Jan 9, 2013 | 08:58 AM
Make the engine that's in it run right first. Make sure the plenum is good, and everything else is up to snuff. Going from a high horsepower, light vehicle, to an underpowered truck.... yeah, there IS going to be a performance difference.
Old Jan 9, 2013 | 11:08 AM
sr20boostjunkie
New Member
Yea that's what I thought so I figured a rebuild and the kegger mod but then thought why not just put a turbo on it and run the other Air gap intake manifold. U know it's low on power and very sluggish now. Not that this is related but thought I'd give a link to a fuel calculator and a good company for fuel parts http://www.deatschwerks.com/resources/fuel-calculators/
