Lifted bumper
Old Jan 14, 2013 | 10:38 PM
PmuLLin's Avatar
PmuLLin
Default Lifted bumper
I had a guy I know put a 3" body lift on my 98 sport but he never ended up doing the front and back bumpers I did the back that was straight forward. But the front looks tricky I can't really find any info for removal of the front bumper and I'd like to kinda have a plan instead of just taking off what I think needs to come off Any one ever done one and have pictures ?? The manual I have isn't a lot of help!! Thank you !!!
Old Jan 15, 2013 | 10:00 AM
Shouldn't be that many bolts holding it on... couple main brackets at the frame, and maybe a couple side braces. You can get new brackets to reposition the bumper to match your body lift. Many companies sell them.... most body lifts come with them....
Old Jan 15, 2013 | 10:52 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
If you got the full kit, which would be by Performance Accessories, then you would have found bumper brackets for the front.
if not, then your kit is incomplete.
You having the Sport has different bumper brackets. Contact PA directly. You can even go to their website or look at your instructions to find the part number.
To remove stock bumper -- just as HeyYou said. there are 6 or so bolts on the cross member. More if you have tow hooks. There is a side support on each side. Unbolt on the frame and on the inside of the bumper. Your neck will enjoy the move.
Old Jan 15, 2013 | 02:57 PM
PmuLLin's Avatar
PmuLLin
I have the brackets I was just hoping some one had a diagram the instructions for the lift aren't very helpful besides saying take off bumper and install bracket.
Old Jan 15, 2013 | 06:05 PM
You are making it more difficult than it really is.
Old Jan 15, 2013 | 09:34 PM
PmuLLin's Avatar
PmuLLin
I know I probably am but I'm just trying to get all the information I can before I go and remove and most likely modify the bumper!!
Old Jan 16, 2013 | 09:13 AM
Have a friend help drop the bumper. They tend to be a bit heavy.
Old Jan 16, 2013 | 01:16 PM
PmuLLin's Avatar
PmuLLin
Should the new brackets match the holes of the old brackets holes or should I be pre paired to drill new holes?
Old Jan 16, 2013 | 09:28 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
should be a no drill aplication unless you have a very cheap no name kit but they usualy dont come with bumper brakets
Old Jan 18, 2013 | 12:21 PM
PmuLLin's Avatar
PmuLLin
Alright well I'm doing this tomorrow since it will be close to 50 here in Ohio ill take a before and after if I remember. Thanks for the tips it looks like hell with that gap right now!
