Suspension lift kit the right way
Old 01-17-2013, 12:47 AM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
Originally Posted by duckslayer5032
ain't cheap to do it right, there's the right way and cheap way
Posted from Dodgeforum.com App for Android
When you're only lifting 3 inches "doing it right" doesn't need to cost 2 grand. Generic spacers/coils, blocks/leafs, and shocks will do the trick just fine.
  #22
Old 01-17-2013, 12:53 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
+1 Matt!!
  #23
Old 01-17-2013, 03:00 AM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
RC componets are fine, I started getting my stuff from them as they're only 25 minutes away from me.
  #24
Old 01-17-2013, 11:54 AM
Johnn123's Avatar
Johnn123
Johnn123 is offline
Originally Posted by dlyter09
You are on a budget so just get yourself a leveling kit.. 2.5 inches should be good. Then throw an add a leaf in the back.. no issues with that. I believe with that setup I could run 35's with little to no issues.
Thats what i got and 35's fit fine. I just get weird rim rub for some reason..
  #25
Old 01-17-2013, 01:54 PM
greanbeans's Avatar
greanbeans
greanbeans is offline
i got a 3 inch spacer on the front of mine and im running 35s on 15s and they only rub at full lock which i can deal with
  #26
Old 01-17-2013, 02:52 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
He wants to do it right... Not try and stuff the largest tire under his truck with the least amount of work... Leveling Kit and AAL are the best bet if you want to stay on the budget side of things and keep it simple... Yes a body lift is easy but it is also more work than anything else... Remember any tire 33 inches or taller it is a good idea to look into a regear.. Your transmission will hate you if you dont.
  #27
Old 01-17-2013, 05:44 PM
Randy Curran's Avatar
Randy Curran
Randy Curran is offline
Originally Posted by dean98ram1500
Yeah, that is true. But like I was saying, my suspension right now is shot, and it needs new shocks. I'm also not a huge fan of blocks or a leveling kit, just to add more tension on my coils anf leafs.
How does a spacer add more tension on your coils????? It does not affect the spring rate at all. Neither does a block. But I hate blocks.
  #28
Old 01-17-2013, 06:13 PM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
I'd say 2.5" hell bent steel spacers up front, 2" aal's in back and the bilstein shocks as previously mentioned.
  #29
Old 01-17-2013, 07:14 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
The reason you hate blocks is because they act as a lever, giving the axle MUCH more torque to apply to the springs, thus, giving you more axle wrap. never a good thing. I was rather surprised to see blocks from the factory... that just has bad idea written all over it.
  #30
Old 01-17-2013, 07:35 PM
redheadhunter21's Avatar
redheadhunter21
redheadhunter21 is offline
I would advise you to skip on rancho shocks had them on my truck and they sucked. Bilstein is a great shock though
Quick Reply: Suspension lift kit the right way
