help ! 1997 ram 5.2 won't start
Hey guys I have a 1997 dodge Ram 1500 5.2 truck that was given to me a year ago . Everything was great till this Nov. The transmission went out on it . So I got it rebuilt and ran great for a month until it died on me in the rain . Now it turns over but will not start. I have replaced the fuel pump, distributor cap, rotor, camshaft sensor, crank shaft sensor, ignition coil, timing chain - as well as checked the timing - to no avail. I'm at a loss for ideas as to what it could be. My next idea is the ignition switch. Any ideas or help is welcome .
If your ignition switch is bad, the engine is not gonna crank at all, replacing it is completely useless. Don't just randomly replace things... Test fuel pressure, should be about 49psi. Test the coil, see if it's getting spark. Do a compression/leakdown test to see if you're losing compression. Any codes coming up?
Wow, that is a lot of parts. + 1 on fuel pressure test. might be the relay. But I would not put anymore parts into it until ypu figure out what is missing. Air, fuel or spark.
maybe have someone pull the codes for you. A mechanic is about a hundred bucks an hour. The fuel pump had to cost twice that.
Thanks, I know I should had waited before replacing all I have done but I always hoped it to be the next part . i just checked the fuel p, and spark . The truck is getting fuel pressure , but I'm not getting spark to the coil . Checked all the fuses and relays , their good . And no codes are coming up , compression test is next
OK I got a friend that runs a shop to come look at it and check the compression on while here . He said it was OK , and I did the relay swap , still nothing . I have a friend that has the same year and engine ram , we mite try his CPU on my truck . And I returned the ignition switch I tried it but nothing .
Trending Topics
