timing 2nd gen
Old Jan 27, 2013 | 08:49 PM
  #21
crazzywolfie's Avatar
crazzywolfie
Originally Posted by Wombat Ranger
That picture looks familiar Wolfie
OP heres a complete description of my extremely effective $100 4000+ cfm e-fan setup. Part number included. best prices for OEM parts at www.weremopar.com in my experience.
lol. ya. you were the only one i know of that has actually posted pictures of installing that fan on a ram and it looked good.
there are lots of different kit fan controller kits listed at summit. if you are thinking about getting a HAYDEN controller you should check out rockauto first. rockauto has 3 HAYDEN brand controlers with sensor and stuff for $10-$15 cheaper than summit. rock auto hides them under Radiator Fan Relay.
http://www.summitracing.com/search/p...an-control-kit
Old Jan 27, 2013 | 10:05 PM
  #22
t's dodge's Avatar
t's dodge
ok bad news got it all put on with the timing chain and found that the shaft on the distributer is also broken and more than likeley out of sinc so i have a new one and need to know proper procedure for install other than the fuel sinc i know i need to have that done afterwords
Old Jan 27, 2013 | 10:09 PM
  #23
Rotate crankshaft in a clockwise direction, as
viewed from front, until number one cylinder piston
is at top of compression stroke (compression should
be felt on finger with number one spark plugremoved).
Then continue to slowly rotate engine
clockwise until indicating mark (Fig. 18) is aligned to
0 degree (TDC) mark on timing chain cover.
(1) Clean top of cylinder block for a good seal
between distributor base and block.
(2) Lightly oil the rubber o-ring seal on the distributor
housing.
(3) Install rotor to distributor shaft.
(4) Position distributor into engine to its original
position. Engage tongue of distributor shaft with slot
in distributor oil pump drive gear. Position rotor to
the number one spark plug cable position.
(5) Install distributor holddown clamp and clamp
bolt. Do not tighten bolt at this time.
(6) Rotate the distributor housing until rotor is
aligned to CYL. NO. 1 alignment mark on the camshaft
position sensor (Fig. 19) .
(7) Tighten clamp holddown bolt (Fig. 20) to 22.5
N·m (200 in. lbs.) torque.
(8) Connect camshaft position sensor wiring harness
to main engine harness.
(9) Install distributor cap. Tighten mounting
screws.
(10) Refer to the following, Checking Distributor
Position.
Step 10 is talking about fuel sync.
Taken directly from the 01 service manual. You can download it in the faq section, Service manual thread. This particular bit is on page 8i-11, and continues on to 12.
  #24
crazzywolfie
are you sure the distributor shaft broke? i am not really sure how you could break one. is the rotor not moving when you turn the cam?
Old Jan 27, 2013 | 10:13 PM
  #25
t's dodge's Avatar
t's dodge
yep u got it the truck will turn over but the button never moves pulled distributer and the shaft fell out. lol not shure how that happened
Old Jan 27, 2013 | 10:14 PM
  #26
QuadCabLuv's Avatar
QuadCabLuv
I also did the efan from wermopar and loved it for the price.
Old Jan 27, 2013 | 10:17 PM
  #27
crazzywolfie
is that shaft still in 1 piece? may have just sheared a pin.
Old Jan 27, 2013 | 10:20 PM
  #28
t's dodge's Avatar
t's dodge
let me look
Old Jan 27, 2013 | 10:33 PM
  #29
gdstock's Avatar
gdstock
Loosen up all the rockers. (if you already have them installed.)
Install cam gear, turn cam so dot on gear is at 6:00 position.
Install crank gear, turn crank so dot on crank gear is at 12:00 position.
Remove both gears, then reinstall with chain.
Verify firing order. I think, but, am not 100% sure, that with the timing gears installed dot to dot, number 6 is at TDC firing position..... I think..... Re-torque rockers, and reassemble. Fire it up.
Gotta make sure #1 is at TDC! Chcek service manual to be sure. And a double roller timing set will be better than the morse style chain like it came form factory.
If it is broken, it could have been what shelled out timing gear.
Old Jan 27, 2013 | 10:37 PM
  #30
gdstock has a point.... and to add to it, might not be a bad idea to take a close look at the oil pump drive shaft as well.......
