Did something stupid: hurt driveline?
Old Jan 30, 2013 | 11:02 PM
  #31
Deadsquiggles's Avatar
Deadsquiggles
Dude, they weren't trying to grenade the trans, there were trying to get the u-joints to snap and flip the car over.
But since they were using a Plymouth, they had to modify the u-joints to break.
Actually, y'all are each thinking of a different episode.
In one episode, they wanted to see the fasted way to slow down a car with no brakes, and one of the ideas was shifting an auto into reverse and park (two separate runs) and then trying to shift a manual into reverse. In the auto, the tranny just disengaged and the car coasted.
In the other episode, they modified a Plymouth so that the front u-joint on the driveshaft failed while driving over a pothole to see if the momentum of the car would use the driveshaft to pole vault the car.
Now, related the OP, I thought if the truck was shifted into reverse or park, the tranny disengages and goes into neutral to prevent damage? Or is that something that was introduced in later models?
Old Jan 31, 2013 | 08:44 AM
  #32
Our transmission are simply slightly modified 727's, so, they do what they are told. Put it in reverse at any speed.... and it will try and engage reverse. Then it just becomes a matter of the weakest link.... that is the part that is going to break. If you have limited traction, might just have the effect of locking the rear brakes. If you have good traction, somethin's gotta give.....
Old Jan 31, 2013 | 09:07 AM
  #33
Jacksoncove's Avatar
Jacksoncove
Originally Posted by gdstock
I have a hypothesis - Trans linkage is slightly misadjusted, and putting in Neural, rooster compb was sitting on detent ball in tranny, and nudged into reverse. Check that adjustment while you are there.
Also +1 on checking mounts and u joints.
Premature speculation, I believe.....
I know two people this happened to and both had to rebuild shortly after
Old Jan 31, 2013 | 09:20 AM
  #34
stewie01's Avatar
stewie01
Time will tell won't it?
Old Jan 31, 2013 | 09:55 AM
  #35
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Nothing broke, engine just shut off. As soon as I realized what happened, I threw it into neutral.
I looked at the rubber mount yesterday, even tried to move the t-case up to check for movement, nothing out of the ordinary. Also tried pushing the driveshaft around and there was no weird movement.
Old Jan 31, 2013 | 10:07 AM
  #36
h3lzsn1p3r's Avatar
h3lzsn1p3r
I have read the whole post he is on borrowed time save for a rebuild!
i have done exactly as descrbed with my old ram trans lasted 100k then i sold it trans woking great
Old Jan 31, 2013 | 10:09 AM
  #37
dodge dude94
This is very true. I don't think it had been that long since the trans was serviced or rebuilt when I bought it. Fluid was pretty clean looking and smelling. Only thing that made me take it in for service a while back was the t-case seal.
Old Jan 31, 2013 | 10:15 AM
  #38
petea216's Avatar
petea216
That could be why it held up so well! Others are right, time will tell. For now, just be observant and do what these trucks were meant to do... drive!
J/W... how do you know two people who just happened to put their automatic transmissions into reverse while cruising foreward at 45+ MPH
Old Jan 31, 2013 | 10:33 AM
  #39
h3lzsn1p3r's Avatar
h3lzsn1p3r
posibly talking about himself or just wants op to pay for a rebuild prematurly
Old Jan 31, 2013 | 10:35 AM
  #40
dodge dude94
Observant? Psh, I'm OCD!
It's all a conspiracy, man!
