V-10
Old Jan 31, 2013 | 02:37 PM
  #21
Originally Posted by petea216
Crap, so to do that I'm gonna need the VIN from the truck the engine came from?
When you switch to the V-10 PCM, you are prolly going to need to get it flashed for the mileage, and VIN for your truck in any event, else it tends to annoy various systems.... (air bag, and ABS.) Once that is done, you can use the tuner on it, and it will be "vin-locked" to that particular vin. MAKE SURE that you get everything on the PCM dealt with FIRST, before you apply the tuner. Change the vin after you apply a tune, and you have a problem.
Old Jan 31, 2013 | 02:53 PM
  #22
petea216's Avatar
petea216
Ok, new question then... how do I get the V-10 PCM Flashed?
Old Jan 31, 2013 | 02:55 PM
  #23
Dealer, or, a good independent shop with the correct equipment. Call around. Shouldn't be more than an hours labor....
Old Jan 31, 2013 | 02:56 PM
  #24
aofarrell2's Avatar
aofarrell2
Dodge dealer will do it for $85 or so in most places.
  #25
redneck_ram's Avatar
redneck_ram
sean (hemifever) can write a program to overwrite the 318 program, and reprogram the pcm to run a 488(v10)
Old Jan 31, 2013 | 03:04 PM
  #26
petea216's Avatar
petea216
I don't think a PCM from a V-8 can run a V-10 due the the lack the the extra two injector circuits the V-10 has and how the V-8's use a distributor for ignition timing where the V-10 uses and fully comp-controlled ignition module. But you guys know more than I do, so I could be wrong. I have the PCM for the V-10. Heck, it's still plugged into it!
Old Jan 31, 2013 | 08:24 PM
  #27
VEETEN's Avatar
VEETEN
Hemifever has written a few tunes for the V10s.
The V10 club may have some more mods for you.
The V10s have very limited aftermarket support, as a matter of fact mine is still bone stock, and still has plenty of power.
What year is the transplant from? the first couple of years the heads were prone to cracking. these are also the years that interchange with the vipers. IIRC 94-96
Old Jan 31, 2013 | 08:41 PM
  #28
gdstock's Avatar
gdstock
Try HERE.
Old Feb 1, 2013 | 07:56 AM
  #29
petea216's Avatar
petea216
Thanks for the help/advice guys! I'm saving this page!
Old Mar 22, 2013 | 09:50 AM
  #30
petea216's Avatar
petea216
Ok, So I've gotten almost everything I need to do the transplant. One more question though... If I have a 47-RE from a truck equipped with a 12 Valve Cummins, do I need to change the torque converter?
6
I didn't see this post before, sorry... it's from a 1996.
