trans line check valve delete
Old 03-31-2013, 03:18 PM
guzman's Avatar
guzman
guzman is offline
That is a factory trans. cooling setup, sure does not look like any of the lines have been replaced. Its been awhile since I got rid of my hose with the check valve in it but I thought mine looked different on the end that comes from steel trans. line??
  #82
Old 03-31-2013, 03:33 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
It's entirely possible that 94 and 95 didn't have one.
  #83
Old 03-31-2013, 04:05 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,262 Likes on 3,009 Posts
Wow. Neat. Is the line swage-clamped to the hard line there? Or is there a flare nut?
  #84
Old 03-31-2013, 04:08 PM
zman17's Avatar
zman17
zman17 is offline
Looks like factory lines with no flare nuts to me. Maybe the RH tranny doesn't reguire it. Either that or it took 3 or so years for them to decide it did.
  #85
Old 03-31-2013, 04:12 PM
HeyYou is offline
Yeah, that's what it looks like to me too.... I was hoping for a simply hose swap for the check valve delete.... Ah well.
  #86
Old 03-31-2013, 04:21 PM
zman17's Avatar
zman17
zman17 is offline
Well PATC used to have one. No longer available I guess. That why drilling it out with a 5/16" bit is the easiest and least expensive way to do it.
  #87
Old 03-31-2013, 04:29 PM
HeyYou is offline
I already replaced mine with some hose, and couple clamps. Didn't think to just drill it out.... also, IIRC, it was leaking at the crimps....
  #88
Old 03-31-2013, 04:44 PM
zman17's Avatar
zman17
zman17 is offline
Yea, the PATC replacement was nice. new hose, quick connect end and crimp end. Just like OEM without the CV.
  #89
Old 04-01-2013, 11:46 AM
Timothy Watrous's Avatar
Timothy Watrous
Timothy Watrous is offline
so dose this mean i should drive it like i deleted the check valve... meaning waiting for it to fill up the TC? how do i tell if the tc is draining after parking?
  #90
Old 04-01-2013, 12:18 PM
HeyYou is offline
Only thing you will notice is after it has sat for an appreciable length of time, it won't want to move well for a few seconds after you first put it in gear. After that, you won't notice anything different.
Quick Reply: trans line check valve delete
