46RE Transmission Slip at 2k?
Old Feb 5, 2013 | 08:54 PM
Yep. Let us know what ya find. (and adjust the front band while you are in there. )
Old Feb 5, 2013 | 08:59 PM
gdstock's Avatar
gdstock
Strange. I was just googling for a pick and pull to see about picking up a tranny to experiment with.....
Dang, Stewie, order the parts and drive it on down (bring beer ). We'll have it done in a weekend!
Old Feb 5, 2013 | 09:06 PM
stewie01's Avatar
stewie01
After consulting the all mighty FSM it looks like it doesn't look like too bad of a chore to adjust the band. The adjusting screw is on the left side of the transmission case above the manual valve and throttle valve levers. Page 2174.
If a band adjustment doesn't fix (more like buy some time) I'll probably have to take you up on the offer. One hell of drive though, just over 1200 miles.
What's your brand?
Old Feb 5, 2013 | 09:11 PM
gdstock's Avatar
gdstock
Originally Posted by stewie01
After consulting the all mighty FSM it looks like it doesn't look like too bad of a chore to adjust the band. The adjusting screw is on the left side of the transmission case about the manual valve and throttle valve levers. Page 2174.
What's your brand?
OP! But prefer a good single malt!
Band is not difficult. But use the torque wrench. May pull and clean sensor and gov solenoid while you are there.
Old Feb 5, 2013 | 09:19 PM
stewie01's Avatar
stewie01
Yea I need to see what's on the magnet or floating around.
For ****s and giggles I looked at the PATC Rebuild Kits, their web layout is very confusing. Need to simplify it.
OP? And you'll have to school me on the good single malt. Oh, have some Cuban's in the humi
Old Feb 5, 2013 | 09:37 PM
OP = Other Peoples'.......
Old Feb 6, 2013 | 10:34 AM
stewie01's Avatar
stewie01
Well I finally got some air filter oil and ATF+4, 1qt filled up, we'll see if it has any affect.
Old Feb 6, 2013 | 11:27 AM
stewie01's Avatar
stewie01
Well I topped off the transmission at the part's store, did some driving around, and it seems to be shifting a lot better. I've got no wild dreams that this will cure the problem, still gonna investigate the pan & solenoids.
Old Feb 6, 2013 | 08:11 PM
caripple's Avatar
caripple
I had a simular problem. It started with the torque converter locking and unlocking while in cruse. Sort of like when you let up on the gas (TC unlocks) then step back down on the gas and TC locks again. Then it got worse it would shift sloppy (rev a little) and some times shift and act like it was going to down shift then shift up again.. I saw a post on this forum about a simular problem and they fixed it with a TPS. I checked mine with an ohm meter and it had dead spots (high ohms) in a couple of places. I did not have a CEL. Replaced the TPS and all seems good now. Time will tell.
Old Feb 6, 2013 | 08:28 PM
stewie01's Avatar
stewie01
I was wondering about the TPS but haven't tested it yet.
