46RE Transmission Slip at 2k?
Old Mar 4, 2013 | 07:19 PM
  #51
stewie01's Avatar
stewie01
Originally Posted by dhvaughan
you got a drain plug? if so you can catch, filter, reuse your expensive $6+/quart atf fluid. otherwise - its awfully expensive to needlessly dump almost new fluid.
I have a drain plug.........to be installed....this go round
Old Mar 4, 2013 | 07:54 PM
  #52
gdstock's Avatar
gdstock
When I did the gov solenoid swap at my son's houes, and when I modded the VB, I drained and reused the fluid as it was good. Strained through automotive paint strainer just to be sure....
Old Mar 5, 2013 | 10:04 AM
  #53
stewie01's Avatar
stewie01
Weather looks to be holding up, so I'm gonna do the swap today. Will have the pictures zman requested up in a lil bit...
Old Mar 5, 2013 | 11:56 AM
  #54
stewie01's Avatar
stewie01
New BW Solenoid and new Pressure Sensor in, pictures coming soon. Time to drill for the drain plug
Old Mar 5, 2013 | 01:22 PM
  #55
stewie01's Avatar
stewie01
Well gents the deed has been done! Install went pretty easy.
Zman, here's the pic you asked for:
Sadly, the block and the solenoid looked to be in good shape, no apparent cloges, screen looks clear.
A tad more debris on the magnet than normal but still nothing to be alarmed about, I don't think anyway...
Refilled with 7qts of fluid. Took on a short test drive, seems ok, a more appropriate test drive will tell the tale...
Old Mar 5, 2013 | 01:55 PM
  #56
zman17's Avatar
zman17
Retired Moderator - RIP
I'm thinking that adjustment screw is in too far and the bands are simply worn or the TC clutches are shot(hence the sludge)and have seen better days. Maybe you'll get a little more out of the tranny from the stuff you've done, but I wouldn't take any long trips. Take a pic of the front one. Hopefully it doesn't look like this one. Name:  DSCF0608.jpg
Old Mar 5, 2013 | 02:20 PM
  #57
stewie01's Avatar
stewie01
Hope I got the pic right, hard to get a good angle.
Old Mar 5, 2013 | 02:29 PM
  #58
zman17's Avatar
zman17
I hate to say this, but your tranny is not going to last much longer. Start saving money.
Old Mar 5, 2013 | 02:30 PM
  #59
stewie01's Avatar
stewie01
Old Mar 5, 2013 | 02:34 PM
  #60
zman17's Avatar
zman17
You got like what? 1 thread showing on that screw and pretty much zero on the other. It's time brotha.
