random start problem
Old Feb 6, 2013 | 04:48 PM
84powerram's Avatar
84powerram
Default random start problem
I have a 2001 dodge ram 4x4 with a 5.2 the truck will run good then you can cut it off and go to start it up and it will just spin over and over if I wait about 30 mins and then it will start right up but it will have a slight skip to it. the truck has gas to the motor it but no spark. it has no cel on and it has 140000 miles on and about a month ago I put new plugs wires cap and button in it what could be making it skip and not fire up at times
Posted from Dodgeforum.com App for Android
Old Feb 6, 2013 | 05:13 PM
Possible crank sensor, or ASD relay. or a number of other things. What codes ya gettin?
Old Feb 9, 2013 | 12:58 AM
84powerram's Avatar
84powerram
no codes yet
Old Feb 9, 2013 | 09:58 AM
No spark would tend to point at the crank sensor.
Old Feb 10, 2013 | 09:24 AM
84powerram's Avatar
84powerram
Ok it did id agen last night and the cel came on I so I resit the pcm and then it fired right up
Old Feb 10, 2013 | 09:57 AM
Did you read codes before the reset?
Old Feb 10, 2013 | 10:08 AM
84powerram's Avatar
84powerram
no I had no way of reading them
Old Feb 10, 2013 | 10:11 AM
For future reference, the 01's let you do the "key trick", cycle the ignition on, off, on, off, on, and codes will display on the odometer.
Old Feb 10, 2013 | 01:00 PM
84powerram's Avatar
84powerram
next time ill do that thanks man
Old Feb 10, 2013 | 04:22 PM
gdstock's Avatar
gdstock
Parts stores can read the codes for you, and a basic code reader is pretty cheap. I recommend getting one. Knowing the code that was set is important to proerly diagnosing failures.
