what tire pressure
Old 02-10-2013, 04:08 PM
rickit's Avatar
rickit
rickit is offline
Default what tire pressure
do i need to run in my 305 75 16 tires on 8 in wheels? i dont do any hauling of anything very heavy and no off roading
Old 02-10-2013, 04:17 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
h3lzsn1p3r is offline
run the pressure listed on the tire place card on the door jam
most people think because they have bigger tires they need more pressure witch is wrong you only need more air in the tire to reach that pressure
Old 02-10-2013, 04:18 PM
gdstock's Avatar
gdstock
gdstock is offline
...OR the pressure indicated on the sidewall of the tire!
Old 02-10-2013, 04:20 PM
cruzer55's Avatar
cruzer55
cruzer55 is offline
Read the script on the sidewall,everything you need too know.Just a thought..
Old 02-10-2013, 04:44 PM
jkeaton is offline
Dodge Forum Administrator
What color is your truck?
Old 02-10-2013, 04:50 PM
97ramrod1500's Avatar
97ramrod1500
97ramrod1500 is offline
The pressure on the sidewall is the MAX the tire should be inflated to. Read what's on the sticker on the door or in the door jamb. Should be either 35 or 50 psi. (My truck says 50) if yours is 50 your tires should be load range E and you should have high pressure valve stems
Old 02-10-2013, 04:52 PM
guzman's Avatar
guzman
guzman is offline
Default Color
Nyuck...Nyuck...
Old 02-10-2013, 05:32 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
i dont know if you are joking or not but the sidewall only has a max psi witch is to much usually on a lt tire
Old 02-10-2013, 05:50 PM
kejobe's Avatar
kejobe
kejobe is offline
For reference,
I have 285/75/16 load E tires. My truck is a 1/2 ton (1500) 4wd. I hual 2500-3000 lbs. in the bed at times; maximum factory capacity is 1500ish lbs. and I also have a plow hanging on the front (400 lbs.). I run 45 psi in all tires.
Normally if you dont haul or have excess weight (plow, etc.) the standard 35 psi should be fine.
Old 02-10-2013, 05:59 PM
gdstock's Avatar
gdstock
gdstock is offline
the sticker on the door jam is ONLY for the type and size tire....described on door jamb. In other words, OEM tires. Since OP is going to a different size/type of tire, it is NOT necessarily appropriate for his new tires!
And my tires list Min and Max tire pressure range...on all of my vehicles.
Quick Reply: what tire pressure
