Trans temp o\d light, aftermarket cooler installed.. have flow..
Old Feb 26, 2013 | 11:37 AM
  #21
gdstock's Avatar
gdstock
Check the connectors at the PCM, see if things are dirty, pulled out, etc. I suspect a shot somewhere if changing the sensor didn't make a difference.
Did you swap out transmission? Were they the same year?
Did you do the check valve delete?
Check the connector on side of transmission as well.
Old Feb 27, 2013 | 01:01 PM
  #22
kuzzy's Avatar
kuzzy
the transmission i installed was a 98, truck is a 99..
deleted the check valve, trans cooler installed. i checked all the connections in the tranny.. however i may be time to take out the multimeter.
i will check the pcm connections.. i remember i had a pcm issue with a dakota i owned before, that was a pain..
  #23
More room in the Ram.
Old Feb 28, 2013 | 01:03 AM
  #24
kuzzy's Avatar
kuzzy
pcm connections looked ok, nothing outa the ordinary/burnt.. connections good.
so.. just now i thought of trying a different pcm in there, and remembered i kept my old pcm from my dak.. hopefully i get some info with that.. keep ya'll posted
