Brush Guard? Adding Cabin Roof Lights?
I have had my lights on for awhile with out any leaks. I wouldn't worry about leaks you can use a small bead of rtv if you want but then there harder to take off if you ever have to replace a bulb. The gaskets work good. When you install the lights don't over tighten the bolts. I have seen people over tighten them and wreak the gasket or worse put a small crack in the lens causing leaks. I don't know why everyone want to tighten stuff as tight as they can get it.
I just added a set of clearance lights to my truck last week! I bought factory replacement ones and drilled away. One of the hardest things I had to do to my truck haha.
I also hand made my deer killer. Only cost me around $50 and doesn't look too bad to me haha. The whole thing weighs in around 250lbs so it might be a little overkill for some people.
heres a good how to, and you can get the kit from mopar for cheap.
http://www.phildorsett.com/clearancelights.html
