Won't rev past 3k rpm?
Old Mar 12, 2013 | 06:25 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Have you tried any of things that have been suggested?
Old Mar 12, 2013 | 11:08 PM
  #22
benmannej1's Avatar
benmannej1
I havent checked the cat yet, but the dizzy is on correctly. What else can i check?
Does anyone know how to actually make it set the fuel sync, instead of just watching it on a solus pro?
Old Mar 13, 2013 | 10:58 AM
  #23
That IS the correct method. Being your readings were between 0 and -2, that falls into the acceptable range. (+ or - 7 degrees) You 'set' it, by moving the dist. You don't need to do that.
What EXACTLY is happening at 3K RPM? Does it pop and sputter? Does it act like it is bouncing off the rev limiter? What?
Old Mar 13, 2013 | 11:32 AM
  #24
benmannej1's Avatar
benmannej1
Its like it just hits a wall, at around 2.5k rpm it starts getting slower, and at 3k rpm it growns and just stops reving any higher. The truck has very little power, and if you go WOT while underload (like going up hill) it just growns and doesnt pick up speed.
Also, do these trucks have a park/ neutral rev limiter?
Old Mar 13, 2013 | 11:36 AM
  #25
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You replaced that damn cat yet? Because it sure sounds like the issue.
Old Mar 13, 2013 | 11:53 AM
  #26
benmannej1's Avatar
benmannej1
haha no not yet, im just trying to rule everything out
Old Mar 13, 2013 | 11:56 AM
  #27
dodge dude94
Judging by your last post. You've got a timebomb with that cat.
Old Mar 13, 2013 | 12:00 PM
  #28
benmannej1's Avatar
benmannej1
Will it run better if i pull the front 02 out?
Old Mar 13, 2013 | 01:01 PM
  #29
Arde's Avatar
Arde
It will if the cats plugged up, but that's not a fix, it'll run rich without the front O2 sensor. It just helps determine whether it's plugged or not.
Old Mar 13, 2013 | 01:39 PM
  #30
gdstock's Avatar
gdstock
I am just on an old country boy, but how can you rule anything out without doing anything? Ruling out suggestions is not very effective....
