Won't rev past 3k rpm?
Mar 13, 2013 | 10:23 PM
Pull the front O2 out of the exhaust. If it runs better, cat is the problem. And that is EXACTLY what it sounds like.
Mar 13, 2013 | 11:14 PM
Quote:
would it also cause it to idle a little rough?
Mar 13, 2013 | 11:59 PM
benmannej1
Gee.....Why do you keep ignoring the suggestions and keep coming back with questions?
Hell, it MIGHT! But we don't know because you won't actually do anything that has been suggested to try to troubleshoot YOUR problem.
If you want help, follow suggestions and mayebe we can help get it fixed. If not......
(is it obvious that my patience is getting thin....?_
Trivia Question: How many posts in this thread have mentioned cat and/or O2 sensor?
Mar 14, 2013 | 12:35 AM
gdstock
I havent had a chance to get under it yet, ive tried everything else that has been mentioned.
Mar 14, 2013 | 10:36 AM
Since you've tried everything else mentioned, and it still does it, that means you've got a bum cat.
Mar 14, 2013 | 10:49 AM
dodge dude94
Well, ill be pulling the 02 today, hopefully its the cat.
If its not i may just drive it off a cliff...
Mar 14, 2013 | 10:51 AM
Mar 14, 2013 | 01:28 PM
[QUOTE=benmannej1;2982209]Well, ill be pulling the 02 today, hopefully its the cat.
If its not i may just drive it off a cliff...[/ QUOTE]
Take pictures!
Mar 14, 2013 | 02:39 PM
okay, so i pulled it out. It got a some power back (will dig a wheel now) but its still not all there. It still wont rev past 3k and still bogs down on WOT underload
Mar 14, 2013 | 02:46 PM
You only have a one inch hole there for the exhaust to escape thru. The cat is clogged.
