ok so i went to two parts stores and couldnt find any noid lights but i picked up some more starting fluid. It fired right up with starting fluid. So cam sensor? Im gonna go ahead and take the one of the 5.2 and see what happens. What all can cause the injectors not to be pulsing? I rechecked the ground to the p/s again its good.
the ground may appear to be good, but the wires may be loose in the ring terminal. check the ring terminal, and then swap out the cam sensor from the 5.2.
ok swaped it out, still doesnt wanna start, its getting fuel now. atleast seems to be, just pulled a plug and its wet now. im gonna change plugs and wires, dist. cap and rotor button and see what happens.
ok without swapping anything yet, i got it running. just a bad miss. AHHHHHH im too excited. man this has been a huge pain in the a**. would plugs and wire be the issue?
Can you narrow down which plug(s) aren't firing? Go from there. Check the plug/wire/connection at the dizzy. Check that injector too, swap it with a injector/plug that is firing right and see if the miss follows
