P1740 engine code
Old Mar 13, 2013 | 10:04 PM
RareColorRam1995's Avatar
RareColorRam1995
Default P1740 engine code
About 20 minutes ago, my check engine light came on. I stopped, cycled the key three times, and read p1740 on the information center. (2001 Ram, 5.9, 4x4) Sadly, I researched and quickly found out it has to do with the transmission. Has anyone else had this code? If so, what did it end up being? I'm going to change the filter and fluid tomorrow and delete the code to see if it stays off. The truck is not slipping/ jumping out of gear, or even operating any differently. I am slightly worried about this, responses would be greatly appreciated. Thanks all.
Old Mar 13, 2013 | 10:15 PM
stewie01's Avatar
stewie01
Old Mar 13, 2013 | 11:24 PM
RareColorRam1995
I've already seen those. Everyone just seems to say, tranny is screwed good luck.
Old Mar 14, 2013 | 12:07 AM
gdstock's Avatar
gdstock
Delete check valve, do the work you referenced, and hope for the best.
Old Mar 14, 2013 | 12:36 AM
RareColorRam1995
Sorry, I can't quote on my iPhone. Gdstock, is there a DIY on that check valve delete?
Old Mar 14, 2013 | 12:40 AM
merc225hp's Avatar
merc225hp
Yes there is a diy on this.
https://dodgeforum.com/forum/2nd-gen...46rh-46re.html
Old Mar 14, 2013 | 05:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Since you are taking the pan off, You should replace the TCC/OD solenoid assembly(since that's what the code is telling you), the gov solenoid(with a Borg Warner),the gov pressure switch, and install a drain plug in the pan. Yes, do the CV delete, but I doubt that's what's causing the code.
