tv cable adjustment needed?
Old Mar 17, 2013 | 07:14 PM
jconlin's Avatar
jconlin
Default tv cable adjustment needed?
i just noticed this after replacing a brake line from the front to the back of the truck, when taking off in first gear when it gets ready to shift the rpms go up slightly and the truck very slightly jerks, also when under heavy throttle the it wont downshift, if i floor it it will only reach 2500 rpms and it just feels like something is holding it back any help is greatly appreciated
Old Mar 17, 2013 | 07:28 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Did you unplug something on the trans by accident or disconnect a cable and not put it back? Go back over everywhere you pulled, pushed while routing the line.
Old Mar 17, 2013 | 07:36 PM
jconlin's Avatar
jconlin
i was never near the transmission, i ran the line down the drivers side where the stock one ran, the only thing i can think of was i had to get close to i think the shift linkage for the column shifter i will go out and look it over though
Old Mar 17, 2013 | 08:22 PM
jconlin's Avatar
jconlin
everything looks fine
Old Mar 17, 2013 | 09:50 PM
gdstock's Avatar
gdstock
Check TV cable and make sure you did not disrupt it when running new line. After that, check TV adjustment just to make sure and eliminate it as a possibility.
Old Mar 17, 2013 | 09:57 PM
jconlin's Avatar
jconlin
Found the problem, the plastic clip that connects the tv cable to the tb was complete busted and the tv cable wasn't even connected, do you know where I could get a new one at? I can't find one on any of the auto parts websites
Old Mar 17, 2013 | 09:59 PM
gdstock's Avatar
gdstock
JY probably. Someone else stated in another thread that dealer only has entire cable assembly.
Gled you found it~
Old Mar 17, 2013 | 10:02 PM
jconlin's Avatar
jconlin
I think I'll plan a trip to the junkyard, I want to get some 3/4 ton front calipers and do that mod also
Old Mar 17, 2013 | 10:12 PM
TiminSoCal's Avatar
TiminSoCal
Default Transmission shop
Check with a Transmission Shop
They should have the piece without
having to replace the whole cable.
Old Mar 17, 2013 | 10:36 PM
jconlin's Avatar
jconlin
Is it like a universal kind if piece? I'm thinking I could almost just make something that will attach the cable to the tb
