Tranny, RPM and Speed
Old Mar 20, 2013 | 02:50 PM
  #21
TheBigRedTruck's Avatar
TheBigRedTruck
just took it on the highway. pressed "od off". no change in rpm or speed
Old Mar 20, 2013 | 02:52 PM
  #22
No change at all??? That's strange, should have at least had TCC unlock for a few. I think....
What surprises me is, you aren't getting any O/D solenoid codes...... I am real curious why not.
Old Mar 20, 2013 | 02:59 PM
  #23
TheBigRedTruck
it is strange. do u think im even in O/D at all?
Old Mar 20, 2013 | 03:02 PM
  #24
gdstock's Avatar
gdstock
No. No OD. Is fluid full (in Neutral and warmed up)?
Should be setting code. It isn't even trying or you would be getting 3-4 shift code.
Old Mar 20, 2013 | 03:04 PM
  #25
stewie01's Avatar
stewie01
And full of the proper fluid?
ATF +4
Old Mar 20, 2013 | 03:11 PM
  #26
TheBigRedTruck
i use atf+4. i warm the truck up doing light driving for 10 mins (no highway). I put it in park, shift through each gear (holding for 3 seconds), then leave it in neutral (running) and get my reading. its between add and full. no codes! lol
Old Mar 20, 2013 | 03:13 PM
  #27
gdstock's Avatar
gdstock
Older tranny, so not entiely sure. But it is not going into OD. Need to check solenoid, but I would look at wiring to tranny fist before dropping the pan.
Old Mar 20, 2013 | 03:18 PM
  #28
TheBigRedTruck
but what about that shift from 48mph. it drops 200 rpm?
Old Mar 20, 2013 | 03:29 PM
  #29
gdstock's Avatar
gdstock
That's TCC. Normal.
Old Mar 20, 2013 | 03:40 PM
  #30
TheBigRedTruck
ooo so its not locking up, just engaging?? if i try to go 60mph do u think i could get a code to come up?
