Tranny, RPM and Speed
Old Mar 20, 2013 | 03:51 PM
  #31
Arde's Avatar
Arde
TC is locking up, OD is not engaging.
Old Mar 20, 2013 | 04:13 PM
  #32
TheBigRedTruck's Avatar
TheBigRedTruck
gotcha, thought they were the same. what does overdrive actually do then?
Old Mar 20, 2013 | 04:28 PM
  #33
Arde's Avatar
Arde
It's a higher gear, like a 4th gear, controlled by that button on your dash.
Old Mar 20, 2013 | 04:29 PM
  #34
izaquad's Avatar
izaquad
It's one more gear. It has a higher ratio to lower rpms at highway speeds to conserve fuel, etc.
Old Mar 20, 2013 | 04:33 PM
  #35
TheBigRedTruck
so i guess its an electrical problem. btw my air box was off (thought it was clamped down to the TB) and i was able to go over 2500rpm in gear. wierd?
Old Mar 21, 2013 | 12:43 AM
  #36
ReadRam's Avatar
ReadRam
Originally Posted by TheBigRedTruck
When I'm at 50mph my rpm is at 2000. It goes into 3rd gear at around 40 and when I hit 48 it shifts down 200 rpm and it reads 50mph at 2000rpm. Any faster I go the rpm goes up with it. What could cause this? I've been topping out at 50mph because I'd rather not go above 2000rpm while traveling on the highway.
If everything is stock you should be hitting 3rd around 25 to 30mph and 1st to 2nd, 15 to 20 mph. Driving like grandpa, anyway. Have you inspected TV cable is secure and nothing broke or binding up? And adjusted right?
Old Mar 21, 2013 | 10:31 AM
  #37
TheBigRedTruck
tv cable is good. i shift out of first at like 20 light driving.
Old Mar 21, 2013 | 06:01 PM
  #38
Augiedoggy's Avatar
Augiedoggy
I know when I had transmission issues in my 96 it did indeed give me multiple codes but no check engine light.... when I asked about it I was told the "check engine" light is just that. Check engine not transmission or drivetrain. It makes sense if you think about it. since if it was for all codes it would say "check computer" or "drivetrain"....
connect a code reader to it and I bet you'll see codes...
others hear will argue you should see the light but I didnt... now the "OD off" button should be coming on automatically when the OD malfunctions or the transmission overheats.
also if you bought it this way,
make sure the right transmission is installed...it sounds funny I know but previous owners have been known to take some crazy shortcuts to sell their truck.
Old Mar 21, 2013 | 11:54 PM
  #39
TheBigRedTruck
the tranny is orginal... the family that had it before me did no changing except a new 3.55 diff... how do i read it with a code reader if it is '95? OD off light only comes on if i press it
Old Mar 22, 2013 | 12:19 AM
  #40
Silver360's Avatar
Silver360
Far be it from me to lend a hand - but you don't by chance have anything else occurring like the rpms constantly surging do you? I had that and from searching here decided to put in a new throttle position sensor. It began to act properly after a few blocks.
