overdrive and TCC lockup
Old Mar 20, 2013 | 02:48 AM
ReadRam's Avatar
ReadRam
Default overdrive and TCC lockup
I have two ram trucks. The 99 with the 5.9 shifts into OD and locks up at the same time, around 42 mph. The 01 with the 5.2 feels like it shifts into OD about 42 mph, drops 200 to 300 rpms, but doesn't do the big drop in rpms until I hit 50 mph. Is that the TCC finally locking in at 50mph. It was explained to me that because the 5.2 has less low end torque it is programmed to lock in later because the 5.2 engine would lug more than the 5.9 at 42 mph. Which is right or are they both right?
Old Mar 20, 2013 | 03:29 PM
ReadRam's Avatar
ReadRam
Anyone with a 5.2, is this how your transmission shifts?
Old Mar 20, 2013 | 03:59 PM
gdstock's Avatar
gdstock
You have it backwards. The first drop is TCC lockup, the second one is OD.
Old Mar 20, 2013 | 06:20 PM
TheBigRedTruck's Avatar
TheBigRedTruck
mine does the same. what rpm are u at when u hit 50mph?
Old Mar 20, 2013 | 08:53 PM
gdstock's Avatar
gdstock
Not sure. I go through 50 pretty quickly. I'll try to look at it tomorrow.....
Old Mar 20, 2013 | 10:24 PM
I run under 1500 RPM at 55, in O/D. I have 265's, and 3.55 gears.
Old Mar 20, 2013 | 11:09 PM
ReadRam's Avatar
ReadRam
Rpm is about 2000 when it shifts into overdrive at 50 mph, then drops to just under 1500. That's at a slow steady increase on the throttle.
Old Mar 20, 2013 | 11:43 PM
gdstock's Avatar
gdstock
I'll try to watch mine in the morning, but my shift points are signifacntly different from stock. But it may help me remamber where they used to be before I modified VB. I know I havve all of this written down along with pressure readings at three ports before I made changes....just don't know wheremy notes are after the move!
TheBigRedTruck
so ur able to go 1500rpm at about 50mph? idk what is wrong with my truck that it strains itself to even go 55mph.
Old Mar 20, 2013 | 11:45 PM
gdstock's Avatar
gdstock
I don't think you are getting OD. Mine would run 3000+ at 70 without OD before.
