Transmission woahs...
Old Mar 25, 2013 | 10:39 PM
redneck_ram's Avatar
redneck_ram
Originally Posted by dlyter09
Hopefully it aint nothing to serious
praying its not!
Old Mar 25, 2013 | 11:06 PM
gdstock's Avatar
gdstock
You could have possibly busted loose some crud like stated earlier.. Might be worth it to drop the pan and have a look to see if anything jumps out at you..
So maybe the lesson here is....electrical parts that are designed to function submerged, may overheat and crater without the fluid surrounding it. Maybe.
What about pulling them out to check visually, then ohm them out and see if they are bad.
Old Mar 25, 2013 | 11:08 PM
redneck_ram
Originally Posted by dhvaughan
do you have fluid flow in the pressure line ?
there was earlier today when the pressure line was leaking at the trans. tightened it up, and then everything happened.
gonna put about 5 gallons of premium in it tomorrow as it literally ran out. then im gonna pull the pressure line off the cooler, and then start it to double check. im praying there is flow.
i could always pull the aux filter and see if there is flow. i really hope its an electrical issue.
it would make sense if it was because the fluid keeps the sensors and solenoids cool, to a point. so maybe they fried themselves...
ill just be glad when it isnt so retarded!
Old Mar 25, 2013 | 11:24 PM
Matt Nickerson's Avatar
Matt Nickerson
(Transmission woes*)
Old Mar 26, 2013 | 07:04 AM
redneck_ram
shudup hahaha i was frustrated, and tired..
Old Mar 26, 2013 | 07:26 AM
redneck_ram
that would be a great idea, but the one tool i dont have.... you guessed it, a multimeter.
Old Mar 26, 2013 | 09:02 AM
redneck_ram
ok, so ive been doing some thinking...
the transmission is most definitely fine, i fried the sensors and solenoids. the truck has been sitting all night, and the trans temp, and o/d off light are still illuminated, and wont shut off.
where is the trans temp sensor on a 46re? is it integraded into one of the solenoids or something?
if i had some gas in it, id unplug the 8 pin round plug and take it for a spin.
gonna replace the electronics, as stated in a previous post. my neighbor with the challenger told me hed lend me money, and the good thing about that is, i can work off the loan, by doing things for him. he has 2, or 3 herniated discs in his back, so anything i can do to help him, is all labor, and money for me.
thats the same way i got my sleep number bed from him for free. plow his and his mother-in-laws driveway all this year to pay for the bed!
Old Mar 26, 2013 | 09:28 AM
guzman's Avatar
guzman
I did not know the answer as the where the Trans. temp sensor is but a search tells me "Its part of the overdrive solenoid inside the transmission on the valve body" Hope this helps.
Temp sensor is part of the governor pressure sensor.
Given that your trans is whining about EVERYTHING in it, I don't think it is a mechanical issue, check to see if some wires didn't get pinched somewhere when reinstalling the engine.
Old Mar 26, 2013 | 09:30 AM
redneck_ram
kinda hard to get pinched when the whole harness was out of the truck, hanging off the drivers side fender.
im going to replace all the sensors/solenoids(again) and hopefully it will fix it.
ill put some gas in it either tonight, or tomorrow morning, and unplug the 8 pin connector and see if that fixes things...
