Steering wheel noise....
Old Mar 26, 2013 | 10:51 PM
maxwgn's Avatar
maxwgn
Default Steering wheel noise....
Another post on noise - after searching, only found one post of like issue, but there were no results / details on the resolution...
I have a friend who just purchased a 2001 Ram1500 Extended cab 2WD. The prior owner had the entire front end freshly rebuilt, with receipt from the shop to prove it. The truck handles fine - the feel is great as far as that goes...
The problem seems to be in the column itself - there is a very bad scraping/grinding sound coming from the column right where the wheel and column meet. The noise is present ANYTIME the wheel is turned, regardless of speed, direction ,etc... IN addition, when the wheel is turned, it feels "notchy" for lack of a better term right now - almost like it's indexed, or ratcheting...
The Rock Solid Ram Steering fix doesn't seem to describe this issue. Also, there is mention of a TSB, but I was unable to find any TSB related to this kind of issue.
This is not his only vehicle, and definitely not a DD, but he would like this fixed ASAP as he does need to use it semi-regularly, and is afraid something is going to give or seize at a bad time, and cause an accident...
ANY help would be greatly appreciated...
Old Mar 26, 2013 | 11:16 PM
Lobo88's Avatar
Lobo88
My truck actually just started doing this also last week. Ive heard of some "clock spring" as the culprit but dont quote me. i havent fixed it yet
Old Mar 26, 2013 | 11:25 PM
gdstock's Avatar
gdstock
go to http://rocksolidramtrucksteering.com/ and order this kit. That will fix it!
Old Mar 27, 2013 | 06:56 AM
dhvaughan's Avatar
dhvaughan
^ that might not do it. that bushing goes in the bottom of the column.
start by downloading the 01 service manual from the 2nd gen FAQ/DIY pages and look at how its put together.
the clock spring makes the electrical connection to the steering wheel functions. if all the electrical things are working, it might be ok.
i don't know if this applies or not, but a buddy of mine with a 1st gen had a floppy steering wheel. we removed the wheel and found a broken bearing in the top of the column. replaced it and it fixed it.
Old Mar 27, 2013 | 10:17 AM
maxwgn's Avatar
maxwgn
Yeah, see, there's NO play in the wheel at all, or the steering... ONLY the noise. It feels like there's a bearing that is TOO TIGHT in the column.
If that repair kit is the correct fix, that's fine - but the site's description simply doesn't match the symptoms...
As for the FSM - I just downloaded it yesterday...
Old Mar 27, 2013 | 10:44 AM
I would be real tempted to yank the steering wheel, and go exploring into the top of the column. There ARE bearings in there..... and your description sounds a LOT like a failed bearing.
Old Mar 27, 2013 | 10:53 AM
gdstock's Avatar
gdstock
Rams appear to suffer from the clunking in the lower bushing more than bearing at the top...but you never know.
Please post up what you find. And make sure you discconect battery forst snd follow FSM. You don't want an airbag in the face!
Old Mar 29, 2013 | 10:54 AM
maxwgn's Avatar
maxwgn
Don't I know it... well, the truck is "on loan" to another friend for a couple of days... friends car died and is in shop... once we have truck back and can dig into the column, I'll post what we find...
Old Mar 29, 2013 | 12:04 PM
zman17's Avatar
zman17
Retired Moderator - RIP
There's nothing replaceable in the column. When you get the truck back, if you can pull and push on the wheel and it moves in and out, it is most likely the bottom bushing. The rock solid will fix it.
