Transmission Beef-up Question
I have a 2000 dodge ram sport 5.9ci with 46re transmission with 138,xxx on it original trans, Is there anything I could do to beef up the transmission that won't exactly break the bank and is simple to install? I know of trans oil coolers, but most of the people I see installing them are towing a lot, this truck just a daily driver/occasional hauler. the trans is not acting up at all, I just wanna prevent future issues. Its my first truck and I really love it. thanks for any input
Trans cooler is NEVER a bad thing. Heat is what kills your trans, so, anything you can do to help keep it around 180 or so, is good. (aux cooler, and temp gauge would be a nice idea.)
Doing a fluid/filter/band adjustment wouldn't be bad either. If you are feelin' really froggy, swap the stock governor pressure sensor/solenoid, for the Borg Warner heavy duty fellers.
Not a lot else you can do without pulling the trans.
And that ain't cheap....
![Smile](https://dodgeforum.com/forum/images/smilies/smile.gif)
Trending Topics
on
https://dodgeforum.com/forum/2nd-gen...r-added-5.html
Page 5, post 45 on my screen... That big *** cooler!
Check valve delete for sure.
https://dodgeforum.com/forum/2nd-gen...46rh-46re.html
As explained by aim4squirrels:
"So why on earth would you want to remove this? Well, if you have debris in your trans fluid from normal wear and tear, a common place for it to collect is in the check valve. When this happens, the fluid flow can eventually stop and with no way to cool the internals of the transmission, it will overheat and die. A failure of this type usually results in a rebuild to the tune of at least $1200 or more."
