oil in intake after plenum repair, pcv?
Old Mar 31, 2013 | 05:12 AM
crazzywolfie's Avatar
crazzywolfie
ya. i pretty much just built a catch can using air tool parts since you can do it cheap. i want to get a better water/oil separator but the one i currently have does its job.
Old Mar 31, 2013 | 09:10 AM
guzman's Avatar
guzman
Default Oil separator
Here is another not so good picture of one I bought on ebay.
Old Mar 31, 2013 | 09:53 AM
You actually WANT the pcv system working as it should. It is fine to have a simple breather on the intake side, but, PCV valve really needs to be there, and hooked to the intake.
PCV draws a slight vacuum on the crankcase, which aids in ring seal, and evacuates combustion blow-by from the case. Keeps your oil cleaner longer.
Old Mar 31, 2013 | 09:58 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I'm going without it. We'll see what happens. I suppose. LOL I change the oil regularly anyway.
Old Mar 31, 2013 | 10:31 AM
Give your oil a sniff every thousand miles or so.
Old Mar 31, 2013 | 10:46 AM
stewie01's Avatar
stewie01
You rebel
Old Mar 31, 2013 | 10:50 AM
zman17's Avatar
zman17
LOL. The under side of the truck is rotting away , so unless I win the lottery, It won't be too long until it's parts truck anyway.
Old Mar 31, 2013 | 11:15 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
here is my solution. oil/water separator installed in the pcv valve line. that is most likely where the oil is coming from.
Where do you get one of those?
Oh, can I have your SCT?
Old Mar 31, 2013 | 11:46 AM
69_XS29L's Avatar
69_XS29L
" What is causing this?? " You have piston ring blow by plain and simple. Your PCV valve is doing exactly what it was designed to do.
Old Mar 31, 2013 | 11:47 AM
dodge dude94
Erm, no.
The pcv naturally sucks in oil because it is using intake manifold vacuum..
