ball joint install using high heat on knuckle
Old Mar 31, 2013 | 08:07 PM
dhvaughan's Avatar
dhvaughan
Default ball joint install using high heat on knuckle
in this video the guy heats up the knuckles red hot to expand the ball joint ring. pretty clever.
do you reckon this does any harm to the knuckle, or causes any permanent expansion or distortion ?
Old Mar 31, 2013 | 09:11 PM
gdstock's Avatar
gdstock
I believe it would. It would alter the tempering on the steel, therefore make it softer and less likely to hold up.
Old Mar 31, 2013 | 09:41 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
it would temper it even more from the heat and would need to be cooled slowly over night before driving it to avoid distortion of the control arm the grease would most likely be garbage in the joint after the intense freezing and then the intense heat
its people like this that do dangerous work on there own vehicles instead of us mechanics dong it safely and properly (of course there are not as many mechanics like myself that only due honest work and don't over charge for labor)
Old Mar 31, 2013 | 09:46 PM
joshmopar's Avatar
joshmopar
Ive done a lot of king pins and balljoints and never needed to do that to get them out. Well king pins maybe but balljoints never.
Old Mar 31, 2013 | 10:04 PM
gdstock's Avatar
gdstock
Slow cooling does the opposite. it would need to be oil quenched to retain temper.
Old Mar 31, 2013 | 10:09 PM
kejobe's Avatar
kejobe
Those words usually do not go together in the same sentence in that order.
Talk about a needle in a hay stack. People like you are few and far between. Keep up the good work!!
Old Mar 31, 2013 | 10:16 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
yes I forgot to mention that when I mentioned the slow cooling thx for the corection
Old Mar 31, 2013 | 10:18 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
it is defiantly a hard thing finding honest mechanics and that is really frustrating that because of the large amounts of bad mechanics we all get a bad name
Old Mar 31, 2013 | 10:37 PM
joshmopar's Avatar
joshmopar
Ill do my own work.
Old Apr 1, 2013 | 08:50 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Idiots like that are Darwin Award contenders. What's worse is they are able to post on the Internet.
It's like the morons on the Garage Journal internet forum who tell people it's OK to plumb compressed air lines with PVC. The Site admin said he was fielding a lot of complaints about my posts and he was getting ready to ban me, so I told him to take his forum and shove it up his **** and that he'd better hope someone doesn't get killed following the dangerous advice from the idiots his moderators are too stupid to censor. I cited every credible source that backed what I said and told him I'd never return. No great loss since 98% of the people who post on that forum have never used a screwdriver before the age of 25 and fawn all over that crap from Harbor Freight.
