Electric fan conversion under $100
Old Aug 1, 2013 | 12:43 PM
  #31
BacT3R1a's Avatar
BacT3R1a
I bought the fan controller at Advance Auto, i'm pretty sure many others have it so they should also carry replacement high power relays. The blue AC wire i connected to one of the 2 black AC wires that come out of the AC compressor, u'll have to try them both and the fan will come on when the AC engages.
Heres a link to the relay http://m.advanceautoparts.com/mt/sho...hTerm=imperial
Old Aug 2, 2013 | 02:06 AM
  #32
Scratcher09's Avatar
Scratcher09
I bought the same controller. I now have it connected to the fan clutch and it is working as it should. I will look for a higher rated relay if the 40 amp one fails again.
Old Aug 2, 2013 | 08:49 PM
  #33
countrystyleram's Avatar
countrystyleram
Maybe one of you guys could help me out. I got the Mark VIII fan from Lincoln, it has a huge surge on startup but it pulls roughly 30-40amps on full pull but its rated for over 3K CFM by itself.
http://www.motortopia.com/files/cars...Thumbnail1.jpg
I bought a kit from summit to hook it up, im curious if I can set the kit to run off the temp sensor from the system, or is there a plug someplace I can put the kit sensor in? I think its a 165-185 kit I cant remember.
Old Aug 3, 2013 | 01:39 AM
  #34
Scratcher09
Countrystyleram, I'm sorry I can not be of any help. I'm not knowledgeable when it comes to electrics. I was only able to do this conversion thanks to the guidance at the beginning of this thread.
Old Aug 3, 2013 | 08:23 AM
  #35
BacT3R1a's Avatar
BacT3R1a
yup, buy what i and many others did, because we cant help you much. Buy whats easy to install, buy what's good.
Old Aug 14, 2014 | 09:18 PM
  #36
Squints's Avatar
Squints
does this replace the fan clutch assembly?
Old Aug 14, 2014 | 10:58 PM
  #37
Ram Driver's Avatar
Ram Driver
Yes, the electric fan will replace the mechanical fan and clutch assembly.
Old Aug 15, 2014 | 12:42 AM
  #38
BBartow's Avatar
BBartow
Not worth it anymore imo. 6 months ago I called the dealership and it was $112. Few weeks ago and they told me $198.26. I'm looking at the FFDynamics kit now for $275. I'd suggest the same.
Old Mar 11, 2018 | 08:23 PM
  #39
Tony Glines's Avatar
Tony Glines
Default Left and right side mounting
How did you mount the left and right side fan brackets to the fan should? Did you use the L brackets on the side also ?
Old Mar 11, 2018 | 11:22 PM
  #40
2bit's Avatar
2bit
Hard to tell it's not factory.
Fits nice with a 1x2 piece of aluminum between it and the shroud.
I
