Slight misfire? Help
Old 04-21-2013, 03:39 PM
gdstock's Avatar
gdstock
gdstock is offline
Originally Posted by zman17
JMO, but it looks to me like it's plenum,cat and o2 time. And also get pcv valve from your local dealer when/if you decide to do the work.
+1. That appears to be a significant amount of oil accumulated, therefore more oil has been burned during combustion therefore, cat and O2 are likely less that in ideal condition.
  #22
Old 04-21-2013, 06:36 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,389 Likes on 3,129 Posts
It won't run as good as it should, but, you can still drive it....... for a while. The cat will eventually clog to the point the engine will barely run. Keep that in mind.
Quick Reply: Slight misfire? Help
