Need Help With Full Tune Up!
Old May 27, 2013 | 09:25 AM
  #21
crazzywolfie's Avatar
crazzywolfie
well acutually up here the premixed stuff is $2 cheaper than the concentrated stuff here but getting 1 gallon of concentrated stuff and 1 gallon of distilled water even if it was to cost $4 more would still be cheaper than buying 1/2 a gallon of water for $15
Old Jun 9, 2013 | 11:37 AM
  #22
ChillyPhil's Avatar
ChillyPhil
I'm bringing this thread back up cause i had some questions.
I went ahead and ordered my tune up stuff from summit which included:
Stant Lev-R Radiator Cap: http://www.summitracing.com/parts/snn-10331
Davis Unified Ignition Cap and Rotor Kit: http://www.summitracing.com/parts/dui-35200rd
Taylor ThunderVolt 8.2mm Spark Plug Wire Set: http://www.summitracing.com/parts/tay-84276
Stage 8 Locking Header Bolt Kits (For my Pacesetter shorties I'm getting Saturday) : http://www.summitracing.com/parts/stg-8935
I do got a question though..... Which bypass hose do i need and which do i not need?
GOODYEAR Part # 63064 I.D. 1.000"; Length 4"
Molded; Cut to Fit
GOODYEAR Part # 63333 I.D. 0.620"; Length 17"
Molded; Restrictor To Engine
I'll keep the list updated on what I buy. I plan on getting the plenum belly pan off the guy on ebay that is a member on here today too. Then i have a bigger list on RockAuto to order.
Old Jun 9, 2013 | 11:53 AM
  #23
zman17's Avatar
zman17
Retired Moderator - RIP
You want the 4" hose.
Old Jun 9, 2013 | 12:02 PM
  #24
ChillyPhil's Avatar
ChillyPhil
Thanks zman!
Here's everything I'm ordering from RockAuto later this week:
NGK Part # 4291 {#ZFR6F11} V-Power
.040
FEL-PRO Part # MS95392 Set
Lower set; Upper set incl.; Manifold bolts not incl.; Manifold bolt replacement recommended
FEL-PRO Part # ES72169
Int. manifold bolts w/Washers; Replacement recommended
FEL-PRO Part # TCS45996
w/o Sleeve 'N' Seal®; Must be used w/OS34408R; PermaDryPlus® timing cover Gasket. incl
CLOYES Part # C3028X Incl. Cam Sprocket; Double Roller Chain; Heavy Duty Timing Set
3 Keyway Crank Sprocket; Incl. Cam Sprocket; Double Roller Chain; Heavy Duty Timing Set
Molded; Cut to Fit
VARIOUS MFR Part # CH3014105 (I need this because mine leaks)
3.9L/5.2L/5.9L; w/o Cap; Coolant recovery tank
Timing Chain Tensioner off of mopartsracing for $31.95
Does all that sound right and is it everything i need for my tune up? I don't think I'll need new o2 sensers because I'm getting a whole new magnaflow high flow cat when i put my Pacesetters on.
Do i need a new coil or would the one in it be fine?
Old Jun 9, 2013 | 12:12 PM
  #25
zman17's Avatar
zman17
I would use plain old copper core plugs, champs or autolite. Up to you.
And no need to replace the coil.
Old Jun 9, 2013 | 12:21 PM
  #26
AtomicDog's Avatar
AtomicDog
You will also need a good set of header gaskets - everyone has their own personal thoughts of the 'best' header gaskets. Listed below are some options:
http://stores.hi-potek.com/-strse-21...dge/Detail.bok
http://www.summitracing.com/parts/mr...iew/make/dodge
http://www.summitracing.com/parts/sc...iew/make/dodge
I personally use SCE copper gaskets, along with some Permatex Orange RTV to ward off dreaded header leaks.
+1 for the copper core plugs. I personally prefer Autolite, as they have performed very well for me over the years - very tough plugs!
When installing your plug wires, helpful to use a touch of dielectric grease inside the spark plug boots - makes them easy to remove off the spark plugs later.. A little dab on a q-tip to apply them to the inside of the spark plug wire boot works for me..
http://www.summitracing.com/parts/lct-37534
Old Jun 9, 2013 | 12:50 PM
  #27
ChillyPhil's Avatar
ChillyPhil
Alright so are these good ones then? http://www.rockauto.com/catalog/more...669&cc=1095735
Is Remflex a good gasket for that price? I heard they are expensive and pretty tough when using it with the stage 8 locking bolts. But I'll probably do the same header gasket setup as you if it been working for you.
And if you just told me an hour sooner on that grease. I already sent my $135 order to summit and it'll have to wait until my next order because i don't want to pay shipping on a $4 item.
Old Jun 9, 2013 | 12:58 PM
  #28
You can get the di-electric grease at most any parts/hardware store.
Old Jun 9, 2013 | 01:03 PM
  #29
zman17's Avatar
zman17
Yep, those plugs are fine. And the new wires should come with a small pack of grease. If not, as HeyYou stated, it can be easily purchased local.
Old Jun 9, 2013 | 01:11 PM
  #30
ChillyPhil's Avatar
ChillyPhil
Ok, I'll check into NAPA when i go into town next. And i went ahead and added them Autolites to my buying list.
Total is 152 with everything and i think they have a 5% code still going on.
Plenum plate is ordered btw.
