99 dodge ram 1500 stalling
Old May 27, 2013 | 02:04 PM
CarolineKeen's Avatar
CarolineKeen
Default 99 dodge ram 1500 stalling
My husbands truck has been stalling off and on for about 4 months. It will stall and if he lets it sit for about 15 min's, it starts with no problem and is fine for 4-5 days. Sometimes it will try to stall and catch's itself while being driven. We had a fellow put a scanner on it, its putting out no codes. We thought we would change the fuel filter, found out its in the fuel tank. My father says change the control Module, but we have not been able to find where it is and how hard it is to replace. My brother is very handy with cars but lives 3 hours away and has been trying to help through phone calls. Can anyone help me locate the control module, so i can find out if this is something my husband and i can replace. Thanks
Old May 28, 2013 | 08:50 PM
jasonw's Avatar
jasonw
Site Moderator
The control module is the engine's computer. Its the big black box on the passenger side of the engine compartment against the firewall, with the large bundle of wires coming out of it.
Before you replace something as expensive as the powertrain control module (PCM), have you tried the other, much cheaper things first? IAC, TPS, etc.?
If you replace the PCM, you'll have to take it to a dealership to get "flashed" with the truck's VIN number. I'd only advise replacing the PCM as a last resort.
Also, for future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old May 29, 2013 | 11:10 AM
zman17's Avatar
zman17
Retired Moderator - RIP
+1.... Try cleaning the IAC first(disconnect negative battery cable before doing so). https://dodgeforum.com/forum/dodge-r...n-the-iac.html
Download the service manual from the FAQ/DIY section. You should have it.
Read the plenum sticky also.
I'm thinking crank sensor, but try the easy stuff first.
Old May 29, 2013 | 03:04 PM
CarolineKeen
My dad did say about having to flash the new computer. My brother is now telling me to try changing the coil. What is the IAC and TPS?
Old May 29, 2013 | 03:31 PM
zman17's Avatar
zman17
Look at the link I gave you, It will at least show you the IAC, which = Idle air control valve. The TPS = throttle position sensor. Also pictured/mentioned in that link IIRC. And get the manual, it will help you immensely.
Old May 31, 2013 | 10:00 AM
CarolineKeen
I have been trying to find the download and cannot locate it. I looked under FAQ and have done a search, but have not found it.
Old May 31, 2013 | 11:12 AM
CSDavies26's Avatar
CSDavies26
https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old Jun 2, 2013 | 08:56 PM
CarolineKeen
Talking
Thank you very much!
Old Jun 2, 2013 | 10:00 PM
dhvaughan's Avatar
dhvaughan
on the stall, the first step is to determine if its lack of fuel or spark.
test for fuel by spraying some starting fluid down the air filter or throttle body. if it starts, or tries to start, then your problem is likely fuel pump, which includes fuel filter, and which lives inside the tank. you can confirm the fuel problem by measuring pressure with a gauge at the test port on the rail. most local parts stores rent/loan the tester for free.
test for spark at the spark plugs. electrical is more complicated. PCM, wiring, crank position sensor, cam position sensor, coil, battery, cables.
other - throttle position sensor (TPS), idle air control (IAC), throttle body iac port, vac leaks, MAP sensor, intake air temp sensor (IAT).
^one of those.....
Old Jun 3, 2013 | 01:40 PM
generaljr's Avatar
generaljr
+1 Crankshaft Positioning Sensor, they cause hard to diagnose intermitent stalls,if its faulty it still could pass the resistance test at ambient temperature, it should be tested at operating engine temperature or more
