Dana 60 1 ton swap into 1/2 ton
Old Jun 9, 2013 | 04:19 PM
dean98ram1500's Avatar
dean98ram1500
Default Dana 60 1 ton swap into 1/2 ton
Well I have a buddy selling Dana 60 from a 1st gen 1 ton 4:10 for $250. My truck is 98 Ram 1500 with a blown 9.25 so I need something quick. Now my question is will it fit? I have a feeling it will, but I don't know if it is worth my time because I do know that would require changing shock mounts, and I'm sure there is other havoc along with it? I do either need to get my 9.25 rebuilt or install this. The other thing i am skeptical about is that the axle is ATLEAST 20 years old. I mean it is a decent price, but I like to do things right and I think I'm going to have this truck for a while. Thanks anyone for your input.
Old Jun 9, 2013 | 04:45 PM
TiminSoCal's Avatar
TiminSoCal
Not positive but I believe you
will have to cut, move and reweld
the spring perches also.
Old Jun 9, 2013 | 05:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It is NOT a direct bolt in. As stated, you will need to do some fabrication.
Old Jun 9, 2013 | 05:57 PM
And there is no provision for the abs sensor on the diff.
Old Jun 10, 2013 | 01:57 PM
dean98ram1500
Ah I didn't even think about the ABS, I would like to keep that, although I'm not certain it works. I don't think I'm ready to do all of that fabrication either, the 9.25 from what I hear is pretty strong, and should be able to withstand what I have in store for it.
Old Jun 10, 2013 | 02:34 PM
I think the rear wheel abs on these trucks is pretty much useless.
Shouldn't be hard to find a 9.25 that will bolt right in though.
Old Jun 10, 2013 | 03:14 PM
Johnn123's Avatar
Johnn123
You say you have 3.55 gears in your sig. I dont think you can have one dif with 3.55 and 4.10 in the other as far as I understand?
Old Jun 10, 2013 | 03:45 PM
stewie01's Avatar
stewie01
not if he wants to use 4wd
Old Jun 10, 2013 | 05:51 PM
zman17's Avatar
zman17
Good call, I missed the "1st gen" part .
