Another Ram 2500 wont start
Old Jun 14, 2013 | 08:24 PM
northamerican's Avatar
northamerican
Default Another Ram 2500 wont start
Battery is good, when I turn the key ebery thing comes on, but seems like no power to the starter, I jumped the starter and it is fine. also I changed the starter switch assambley, still same issue. WTF do I do next??
Old Jun 14, 2013 | 08:36 PM
Matt Nickerson's Avatar
Matt Nickerson
Did you try cleaning the terminals/cables? Are ground connections clean and tight? How do you know the battery is good, has it been load tested? If all that's good, you either have high resistance in the battery/starter cables or the park/neutral safety switch may be malfunctioning.
Old Jun 14, 2013 | 08:39 PM
northamerican
battery is good , from time to time it starts as it should, but 90% of the time it acts as decribed
Old Jun 14, 2013 | 11:21 PM
northamerican
could it be a bad neutral safety switch?
Old Jun 15, 2013 | 03:46 AM
ryan0714's Avatar
ryan0714
solenoid bad on the starter? or the relay
Old Jun 15, 2013 | 07:11 AM
northamerican
checked relay it is good, solenoid should be good the starter is only a year old but is there a way to check that?
Old Jun 15, 2013 | 09:49 AM
Swap the starter relay with another one. See if the problem goes away.
When it won't start, are you getting 9 volts (at least) at the small wire on the starter solenoid?
All connections clean and tight?
Old Jun 16, 2013 | 07:46 AM
northamerican
connections are good, battery, and starter are less than a year old, relay has been swapped for new one, haven't checked small wire for 9V yet, ign key switch has be changed, still no start,
Old Jun 16, 2013 | 10:19 AM
See if you are getting power at the starter solenoid then. Take it from there.
Any variety of aftermarket alarm on the truck?
