small air hose looks like it was cut. please read!!
Old 07-03-2013, 02:17 PM
BrandonBuc'em's Avatar
BrandonBuc'em
BrandonBuc'em is offline
I got it pretty good. And yes, heater core went on me about a month ago. It's 95 degrees up here in pa. I'll fix it in the fall.
Only thing that confuses me is how was that line cut so cleanly, I don't understand.
Old 07-03-2013, 03:19 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,392 Likes on 3,132 Posts
Its plastic.... with age, it gets brittle, and if you look at it wrong, it will snap right off.....
Old 07-03-2013, 03:41 PM
BrandonBuc'em
So me driving hard caused it to look like I took a razor blade to it? That's crazy
Old 07-03-2013, 03:55 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Yep.
As I said months ago:
You're working on a Dodge, anything is possible.
Old 07-03-2013, 07:58 PM
BrandonBuc'em
Thanks everyone
Old 07-03-2013, 08:34 PM
Spillage's Avatar
Spillage
Spillage is offline
Windshield washer line should fit, just cut an inch off it and use it to splice the vac line.
This is what I did when the vac line for the climate control chaffed through on the firewall.
Worked a treat.
Old 07-04-2013, 12:58 AM
BrandonBuc'em
I clamped a rubber type over it. It'll never come apart again.
What is everyone's opinion on sea foam?
Old 07-04-2013, 08:45 AM
dodge dude94
SeaFoam?
I use it. Clean out carbon good if you do it right.
Old 07-04-2013, 03:26 PM
BrandonBuc'em
Change the oil after 50 miles? That's what I did. Well doing right now. Have to wait for it to cool down so I can get the oil cap off.
Old 07-04-2013, 03:35 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Been hearing things through the grapevine from different mechanics saying it will ruin the cat and o2's (no matter what it says on the can). Fix your plenum and install a catch can for the pcv, and use some Techron in the gas once a month and you won't need to Seafoam.
Quick Reply: small air hose looks like it was cut. please read!!
