2000 Ram Sport 1500 4x4 HELP!!
Old Jul 11, 2013 | 02:48 PM
zman17's Avatar
zman17
Retired Moderator - RIP
DId you adjust the cable???? Get one of these also. http://www.doghousediesel.com/catalog/i307.html
Old Jul 11, 2013 | 03:15 PM
With no codes, I would go for the Borg Warner heavy duty governor pressure solenoid, and sensor set.
Old Jul 11, 2013 | 03:27 PM
zman17's Avatar
zman17
Which btw, can also be found on ebay for cheaper. (forgot to mention)
Old Jul 16, 2013 | 03:36 PM
dk_kalla's Avatar
dk_kalla
the tv cable is correct..my next move is going to be dropping tranny pan again and i will replace governor pressure solenoid and sensor..i hope this fixes my problem
Old Jul 16, 2013 | 04:00 PM
dk_kalla's Avatar
dk_kalla
Brand New Borg Warner Governor Pressure Solenoid & New Oem Pressure Transducer. That what i need...right? Pressure transducer is that the sensor? i just want to be sure..thanks
Old Jul 16, 2013 | 04:13 PM
That is correct.
Old Jul 16, 2013 | 04:25 PM
dk_kalla's Avatar
dk_kalla
thanks for the quick response and your input
Old Jul 16, 2013 | 04:26 PM
dk_kalla's Avatar
dk_kalla
i will be fixing it next week sometime and will post my results
Old Jul 16, 2013 | 04:29 PM
See if you can scare up a small torque wrench that can accurately do 72 INCH pounds, and adjust the bands while you are in there.
Old Jul 16, 2013 | 05:03 PM
dk_kalla's Avatar
dk_kalla
ya i have one :P..thanks....i just drove the truck and now it doesn't want to shift from first gear unless i let off gas pedal.. if i rev it under 2800 rpm it and let off gas it will shift to second, if i rev to 3000+ rpms and let off gas it will skip second and go to third haha ????
