ground problems after bed re-install..
Old Jul 27, 2013 | 08:38 PM
redneck_ram's Avatar
redneck_ram
Originally Posted by dhvaughan
just resplice yours ??
ive given that a though. i think im going to re-wire the entire thing. using the heat shrink butt connectors. that way it will basically be a brand new harness.
if that doesnt work, ill buy a new one.
Old Jul 27, 2013 | 09:21 PM
dhvaughan's Avatar
dhvaughan
i didn't know you could buy a butt connector with heat shrink tubing already around it. what a good idea.
3M Heat Shrink Butt Connector Kit 140 Piece: Amazon.com: Industrial & Scientific 3M Heat Shrink Butt Connector Kit 140 Piece: Amazon.com: Industrial & Scientific
http://www.harborfreight.com/30-pack...ors-66729.html
Old Jul 27, 2013 | 09:51 PM
redneck_ram
yeah thats what those butt connectors are in the pic above. just didnt have a heat gun to shrink the tubing.
as stated, gonna re-wire it, and hopefully itll take care of the issue. if not, to the dealer it is!
Old Jul 27, 2013 | 10:08 PM
kejobe's Avatar
kejobe
Don't need a heat gun, just use a lighter.
Old Jul 27, 2013 | 10:09 PM
That's what I use. Just be careful not to set it on fire. (don't ask.)
Old Jul 27, 2013 | 10:20 PM
redneck_ram
Eh I have a heat gun.. easier to use.. and not chance of fires. ;-)
Old Jul 27, 2013 | 10:22 PM
Yes there is.
Old Jul 28, 2013 | 10:15 AM
Jimythefan's Avatar
Jimythefan
Where's the fun in that?
Old Aug 14, 2013 | 09:45 PM
redneck_ram
My buddy gave me his trailer wiring harness off his 99 1500. Got it installed and the reverse lights are still coming on with the brake lights. Hmmm...
Originally Posted by beginningjockey
^check all the grounds RR. Sounds like you are missing one - had the same thing happen.
There is only one ground that I disconnected.... well 2 actually. The I ne that goes to the trailer harness (which has no effect on anything but the trailer side) and then the bed to cab ground. Its all tight and grounded properly
Any other sections to check?
All fuses that deal with that stuff are good. So im at a loss.
What year is your truck? Same year?
Originally Posted by QuadCabLuv
Sounds like a shorted bulb socket. Are they all in good shape? With someone holding the brake pull out one bulb at a time and see if the reverse lights go off.
Truck is a 2001. Harness is the same from 98-2004
The sockets are in good shape so far as I know.
How would I go about replacing the socket? Just splicing in a new one?
So heres a vid of what happens when a reverse bulb is unplugged. However this only happens when the trailer tow harness is connected. If I completely unplug the trailer harness and just plug in the main harness it doesnt do this.
This also only happens on the drivers side. Now... when I turn the parking lights on thry come on, but as soon as I hit the brakes, the drivers side goes completely out. But again only when the trailer harness it plugged in. So im thinking it has to do with the tail light wiring after the trailer harness (socket side)
Thoughts?
hmmm ya know what.... are the sockets side oriented? im wondering if the socket harness on the drivers side, is supposed to be on the passenger side, and vice versa?!?!
Old Aug 14, 2013 | 11:56 PM
Use your turn signals to verify correct placement.
