ground problems after bed re-install..
Old Aug 17, 2013 | 11:12 PM
  #31
Originally Posted by redneck_ram
well, the socket pig tails are not side oriented... i went out and swapped them, and it did the same thing. the drivers side is just not burning hot enough, and the reverse lights are still coming on.
but i did find out, and confirmed, that when the the trailer harness is unplugged and the tail lights are plugged in without the trailer harness, the lights work as they should, without the reverse lights coming on.
im at a huge loss, and dont know what to do... the trailer harness is unmolested, and is in great shape. so its not that.
edit... also, i can take either reverse light out, doesnt matter which side, and they no longer are on with the brakes. however if both reverse bulbs are in, and you take the drivers side brake/turn bulb out, the reverse lights go out as well, but only when the trailer harness is connected.
That right there tells me the problem is in the trailer harness. Is it possible to simply plug it in wrong?? If the harness worked fine on another truck.... but, doesn't want to work on yours, compare pinouts of the connectors for both years of trucks, (which should be the same, if the trailer harness is the same.) and maybe verify that the wires haven't been shuffled on your harness.
That is about the only thing I can possibly think of that would cause what you are seeing. If you weren't 400+ miles away... I would be real tempted to come over and have a look. Just out of morbid curiosity.
Old Aug 18, 2013 | 08:36 AM
  #32
stewie01's Avatar
stewie01
I thought it was a bad ground?
Old Aug 18, 2013 | 09:00 AM
  #33
redneck_ram's Avatar
redneck_ram
I thought it was too.. but I fixed all the grounds I could find. So now the multifunction switch, nss, and the ctm are up for testing.
Anyone got a ctm they could spare?
Old Aug 18, 2013 | 11:35 AM
  #34
zman17's Avatar
zman17
Retired Moderator - RIP
I really don't think the CTM is the problem.
I have another thought, I'll call you right now.
Old Aug 18, 2013 | 02:25 PM
  #35
redneck_ram
im home from work on lunch at the moment, so ill poke around a bit. so far, the steering column wiring looks ok, but i havent actually dug into it, just looked at it quick.
Old Aug 25, 2013 | 09:13 PM
  #36
redneck_ram
so this issue is finally BUSTED!!!
it turned out to be the trailer harness after all. the ground wires were corroded internally on part of the trailer harness(literally a 4" peice of wire) that caused the whole issue.
so, now its all fixed, and i need to invest in a multimeter! had to borrow my neighbors meter to figure it out.
plus side to all this?? all my grounds are brand new!
Old Aug 25, 2013 | 10:08 PM
  #37
Maybe you will believe me next time.
New, clean grounds is never a bad thing.
Old Aug 25, 2013 | 11:06 PM
  #38
redneck_ram
well.... i honestly didnt think it was it, because it worked fine on my buddys truck.
guess my damn french canadian stubbornness got the better of me!
Old Aug 26, 2013 | 01:16 AM
  #39
Paul DeHayes's Avatar
Paul DeHayes
^^^You silly king-ah, LOL
