1995 Dodge Ram/Installed new long block...issues
Old Aug 1, 2013 | 02:41 PM
moparchic's Avatar
moparchic
Default 1995 Dodge Ram/Installed new long block...issues
Installed new long block. Timing marks are ok. Distributor gear installed correctly. Distributor and rotor lined up to mark on pickup coil at #1 TDC and truck will not start. Have to turn distibutor to extreme counterclockwise and then truck starts but run poor. Suggestions??
Old Aug 1, 2013 | 03:16 PM
Arde's Avatar
Arde
Turning the distributor alters your fuel synch., not ignition timing. Take it to a shop and get the fuel synch. set. Or take it to a dealership.
Or
https://dodgeforum.com/forum/2nd-gen...ml#post3045075
Old Aug 1, 2013 | 04:13 PM
moparchic's Avatar
moparchic
can't I set the fuel sync myself?
Old Aug 1, 2013 | 04:34 PM
TiminSoCal's Avatar
TiminSoCal
Here's the instructions
http://www.bionicdodge.com/bionic%20downloads.htm
Old Aug 1, 2013 | 05:02 PM
distributor 180 out? That would have it firing the wrong cylinder....
Old Aug 1, 2013 | 05:08 PM
moparchic's Avatar
moparchic
8 wasn't firing....now it's 6
Old Aug 1, 2013 | 10:17 PM
Pull the distributor, pull your number one plug. Turn the engine by hand until you feel compression blowing out the number one spark plug hole. Set engine to TDC for number one. Follow procedure in SM to re-install distributor.
