Is this normal?
Old Aug 3, 2013 | 09:47 PM
MaxPower1971's Avatar
MaxPower1971
Default Is this normal?
I finally got time to drop the transmission pan on my 94. I was expecting a lot worse!
The oil was kinda brown, it's been a while lol, and a bit foul-smelling. But I didn't really find a lot of shavings in the pan....unless you guys tell me that's a lot of shavings??
Also, I used 6.5 quarts from just dropping the pan...is that normal?
Old Aug 3, 2013 | 10:02 PM
stewie01's Avatar
stewie01
That looks like a fair amount to me, even more floating around the pan...
How does the transmission perform?
And it usually makes me 6.5-7qts to refill after a pan drop...
Old Aug 3, 2013 | 10:08 PM
MaxPower1971
Well the tranny was starting to act up right after warm up...I would loose overdrive (works fine the first 5-10 minutes) and the lower gear shifts would happen at higher speeds. I tfor a drive after the oil change but didn't go on the highway. The shifts were nice and smooth, even after it was warm. I will take it out tomorrow to see if I have overdrive. But so far it shifts way smoother.
Old Aug 3, 2013 | 10:16 PM
That doesn't look bad at all, I have seen far worse on trannys that still ran another 50,000 miles.
The fluid smells bad even when it is new......
Old Aug 3, 2013 | 10:25 PM
MaxPower1971
Thanx man...I didn't think it was all that bad for a truck with 160000 miles on it with very ''light'' maintenance done to the tranny. (Light being oil was changed only once )
And you're right...I smelled the new one for comparison and it does smell awful loll
BTW I used Mobil1 syntetic ATF +4....9$ a quart.
Old Aug 3, 2013 | 10:32 PM
stewie01's Avatar
stewie01
Gear oil smells worse!
$9? Ouch..
Cheapo WalMart SuperTech ATF+4 would have worked....
Old Aug 3, 2013 | 10:48 PM
MaxPower1971
$9? Ouch..
I looked at a few oils and they felt very liquid compared to the Mobil....
But hey...this is Canada, actually Quebec, where we are taxed 42% on our income and even when our dollar is equal to yours...we still pay 20% more than you Americans....for the same product....
Old Aug 3, 2013 | 10:50 PM
stewie01's Avatar
stewie01
Ah. I didn't pay attention to location! That certainly makes a difference.
I can get the Valvoline Full Synthetic for about $7 a quart...
Old Aug 3, 2013 | 10:53 PM
MaxPower1971
Wish I could get a green card lollll Or maybe Obummer will make up some kinda ''legalize the illegals'' for Canadians too?? :P
Old Aug 4, 2013 | 09:29 AM
Sneak into the country and start going to school. Obama will love you forever, and give you a card to stay.
