Help wat did I do wrong
Old Aug 21, 2013 | 08:24 PM
95 dakota sport's Avatar
95 dakota sport
Default Help wat did I do wrong
I did the plenum gasket and now the motor has a knock I was careful and cleaned the intake off be for I took it off the motor is there something I can do to fix it befor the motor goes as soon as I heared it I truned the motor off
Old Aug 21, 2013 | 08:46 PM
Matt Nickerson's Avatar
Matt Nickerson
Did you change the oil and is the dipstick in the safe zone?
Old Aug 21, 2013 | 08:55 PM
95 dakota sport
Yes two both the oil is just under the full line
Old Aug 21, 2013 | 08:59 PM
dhvaughan's Avatar
dhvaughan
remove the spark plugs and use a 1-1/4 socket to manually turn the engine using the crank bolt. see if you can find the noise point.
did you remove the starter and inspection cover over the torque converter. if so- take this back off first, as its easy to get it on crooked and the flex plate will hit it. i did this and it made a helluva racket.
Old Aug 21, 2013 | 09:05 PM
95 dakota sport
Ok I'll have to try that it sounds like its coming from cil 6 or 8
Old Aug 21, 2013 | 10:21 PM
Didn't drop something into the port did you?
Old Aug 21, 2013 | 11:09 PM
95 dakota sport
Not that I know of it almost sounds like its not getting oil
Old Aug 21, 2013 | 11:32 PM
Rockslam's Avatar
Rockslam
How long was it apart for? Is the sound like a rod knock or more like a lifter tapping?
Old Aug 21, 2013 | 11:40 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Rag on the oil pump pickup?
Old Aug 22, 2013 | 05:18 AM
ryan0714's Avatar
ryan0714
lol id shoot myself if i forgot to take the rag out....
