Possible bad PCM
Old Dec 18, 2013 | 04:51 PM
  #31
Time for a new PCM?
Old Dec 18, 2013 | 05:04 PM
  #32
bgmins's Avatar
bgmins
No, it's running fine now. All it needed was for the fault to make contact. So I put some cardboard in between the silicone and the plate and it worked.
Already drove it around the block and there were no hiccups.
I wonder how long that's going to last though.
Old Dec 18, 2013 | 05:18 PM
  #33
Exactly. Replace it now, while it's convenient, rather than have it crap out on you when you need it most.
Old Dec 18, 2013 | 05:33 PM
  #34
bgmins's Avatar
bgmins
Nah it's alright if it does crap out I have another truck that I'm driving now.
Old Mar 7, 2014 | 08:10 PM
  #35
bgmins's Avatar
bgmins
So the comp did eventually crap out and I replaced it recently. But there's no spark now.
I changed the coil and still no luck.
Where does the coil get its signal from?
Old Mar 7, 2014 | 08:11 PM
  #36
bgmins's Avatar
bgmins
And thanks HeyYou for the help.
Old Mar 7, 2014 | 09:05 PM
  #37
Crank Sensor.
Did the new PCM ever work at all? Wouldn't be the first time someone got a bad one. Not like they are new or anything. The ones you get from the parts stores are reman....
Old Mar 8, 2014 | 07:50 PM
  #38
bgmins's Avatar
bgmins
New pcm never worked.
So if the crank sensor is good then that leaves the comp at fault?
Old Mar 8, 2014 | 09:52 PM
  #39
There is a resistance test for the crank sensor, procedure is in the Service Manual.
If it never worked with the new PCM, try a different one.
Old Mar 9, 2014 | 11:29 AM
  #40
bgmins's Avatar
bgmins
I couldn't find the test I only found mention of the sensor under ignition control?
