95 5.2 ?
Old Sep 10, 2013 | 10:00 AM
  #31
No spark AND no fuel indicates ASD problem. Swap the ASD relay, and the horn relay. See if that makes a difference.
Bear in mind, you will only have power at the coil and injectors for about three seconds (while fuel pump is priming) if the PCM doesn't see the engine turning.
Old Sep 10, 2013 | 12:12 PM
  #32
zman17's Avatar
zman17
Retired Moderator - RIP
Check all ground wires also. 2 by PS pump and 2 on firewall by passenger side head/pcm.
Old Sep 10, 2013 | 07:42 PM
  #33
getdown78's Avatar
getdown78
Can i cross the asd relay and make it work ?
Old Sep 11, 2013 | 10:12 AM
  #34
getdown78's Avatar
getdown78
Where can i get a good wire diagram of the asd relay ?
Old Sep 11, 2013 | 10:53 AM
  #35
See if you are getting power to the coil/injectors before bypassing anything.
Wiring diagrams are in the service manual, that are downloadable in the FAQ/DIY section here. (service manual thread)
Old Sep 11, 2013 | 04:43 PM
  #36
zman17's Avatar
zman17
For a 96, a Haynes manual is very helpful also.
Old Sep 11, 2013 | 11:24 PM
  #37
getdown78's Avatar
getdown78
Ok, i got both the haynes and chilton !
Old Sep 13, 2013 | 05:32 PM
  #38
getdown78's Avatar
getdown78
Well figured out the problem, wires are almost broke at the crank sensor ! How do i know which one it is ? Advance shows about 6 different ones ?
Old Sep 13, 2013 | 11:03 PM
  #39
Different manufacturers, and difference between auto/manual trans, and probably number of cylinders as well. (V-10 is gonna be different)
Get Standard Motor Products, Delphi, or from the dealer. Anything else may just leave ya hangin'. If you can, bring in your old one, and compare to the new one.... make sure you get the right one, the first time.
Old Sep 14, 2013 | 03:36 PM
  #40
Johnn123's Avatar
Johnn123
+1 on getting a standard motor products or delphi sensor, dont go napa or similar brands thry suck. Also def a good idea to bring in the sensor , no point in multiple trips lol
