A/C not cool enuff
Old Aug 24, 2013 | 07:38 PM
gotrammit's Avatar
gotrammit
Default A/C not cool enuff
I have a 1996 Dodge Ram 1500 5.2. I had new compressor and drier replaced and recharged. However the a/c is still not cooling too good. Do I need to replace the condenser as well? It is sort of beat up.
Old Aug 25, 2013 | 04:03 PM
Ramman18's Avatar
Ramman18
Make sure the charge was the correct amount. They take 2 lbs I think. When they are either under full or OVER full, they will not cool properly. Then check for:
-leaks
-blend door operation
-blower motor operation
-compressor operation
-condensor (it may just be a bit stopped up too)
Old Aug 25, 2013 | 08:39 PM
ryan0714's Avatar
ryan0714
you can test the condensor by turning the truck on and ac on full blast, then jimmy rig a garden hose to shoot cold water on the condensor while you sit inside and feel the vents. if it gets colder then i would look into the condensor. it could also be the orifice tube aint workin.
Old Aug 26, 2013 | 01:50 AM
sunflake9's Avatar
sunflake9
Sounds like a charge problem to me. Remember that when the truck isn't moving the air passing through the condenser is limited to the fan only. This is why when your stopped at a red light the air temp rises. And then gets colder when you're moving. You could have a partially blocked orifice tube. My guess is a refrigerant charge issue. Also keep in mind that you just had it serviced and they may not have gotten all the fittings tight enough and you could have a leak as well.
Hope this helps.
Old Aug 26, 2013 | 07:17 AM
DeeJayh's Avatar
DeeJayh
Sorry to steal the spotlight, how does one go about this?I think mine Is messing up too
Old Aug 26, 2013 | 07:52 AM
98 is cable operated. I think the electrically powered feller was an advent of the 00 model year. There is a procedure in the 96 manual for adjusting the cable..... Might try that first.
Old Aug 26, 2013 | 12:50 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'd replace both check valves in the vac lines, check fan clutch, 134a charge numbers. And here is how to check and adjust the blend door cable.
Attached Thumbnails A/C not cool enuff-dscf0460.jpg
Old Aug 27, 2013 | 06:38 AM
DeeJayh's Avatar
DeeJayh
That helped immensely, thank you. Now I can hear the blend door touching base at both ends of the spectrum... Just gotta figure out the a/c issue now. Thank god I do HVAC for a living right? =)
Old Aug 27, 2013 | 11:22 AM
Ramman18's Avatar
Ramman18
Is that ^^^^ adjustment for 1999 also?
Old Aug 27, 2013 | 11:51 AM
zman17's Avatar
zman17
Some 99's started using the electric motor. You'll have to look.
