steering alignment
Old Sep 2, 2013 | 06:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Either way, you need an alignment in one form or another.
Old Sep 2, 2013 | 06:43 PM
5speedftw's Avatar
5speedftw
yup thats next on the list,
if only i could fix my gearbox first.. pitman arm? more like pain in my not quite arm
Old Sep 2, 2013 | 06:45 PM
Replace the gearbox with a borgesen, or Redhead. Stock replacements just give you the same problems.
Old Sep 2, 2013 | 06:49 PM
zman17's Avatar
zman17
And btw, I'm merging your your pitman arm thread with this one, since it is all related.
Old Sep 3, 2013 | 12:28 PM
Ramman18's Avatar
Ramman18
How to get pitman arm off: buy a new pitman with replacement steering box. Remove box and old pitman arm as a unit. Throw away old box and arm. Install new arm on new box. Open fridge. Open beer. Enjoy.
Old Sep 3, 2013 | 02:24 PM
Slightly more expensive, but, most certainly a lot less frustrating. Fewer busted knuckles too......
Did I mention I like the way you think?
Old Sep 3, 2013 | 02:30 PM
5speedftw's Avatar
5speedftw
thanks guys but the beers were step 2 after beat head with wrench hahah
Old Sep 4, 2013 | 09:03 AM
5speedftw's Avatar
5speedftw
okay so i finally got it off where it goes into the gearbox.. day 5 of the thing being cranked on there i got home from work. went to tighten it and was like whys it so loose? wasnt sure if i was loosening it or what then the thing dropped right down off.. so i guess the moral is dont expect it to be a fast process!
Old Sep 4, 2013 | 12:20 PM
Rescue35's Avatar
Rescue35
I had a 2wd 1500 that I was replacing the steering joints on. Dodge, in there wisdom, decided that the wearable part should be made into the pitman arm for the 2wds. I tired pullers and impacts for about 3 minutes before breaking out the 4.5" rotary abrasive wrench. After a few seconds with the grinder I had a nice slot ground mostly through the pitman arm. Put a chisel in the slot, hit with hammer to finish spliting. The slightest pressure from the puller and it slid right off.
Old Sep 4, 2013 | 02:07 PM
5speedftw's Avatar
5speedftw
yeah the grinder was about to come out but luckily mine just popped off before i went that far.. i think the only reason it popped after so long is cause it got cooler out yesterday
